Posix priority vs. RTEMS priority (Sebastian Huber)
    Sebastian Huber
    Mon Apr  3 05:39:23 UTC 2017
On 31/03/17 20:22, Heinz Junkes wrote:
> thank you for your answer. In the RTEMS Manual you can read
> that the initialization task should run at Maximum Priority (Classic API).
> (which sounds reasonable)
> If then the POSIX_Init should also be startet at that level -> POSIX
> prio 254?
> Instead of the low prio “2” ?
I am not sure if this is a bug or feature, but changing this would alter
the behaviour of all existing applications using POSIX initialization
threads.
You can change the priority in your initialization thread or we may add
a new configuration option, e.g.
CONFIGURE_POSIX_INIT_THREAD_PRIORITY
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
