RTEMS 4.11.2-rc3 Release
Sat Apr 8 23:29:53 UTC 2017
On 9/4/17 8:18 am, Chris Johns wrote:
> The VERSION INI file that is embedded in the RC's RSB package should
> contain a `release_url` key/value pair that points to the RC sources on
> ftp.rtems.org using the https protocol.
> This raises a couple of questions, there is still a bug in the get_file
> function in download.py, and why do I not see this on FreeBSD yet you
> see it on CentOS7?
Are you using Python3? Python3 is working for me on FreeBSD.
The following is running on FreeBSD:
ruru 4.11 $ curl -o rtems-source-builder-4.11.2-rc3.tar.xz
https://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc3/rtems-source-builder-4.11.2-rc3.tar.xz
  % Total    % Received % Xferd  Average Speed   Time    Time     Time
Current
                                 Dload  Upload   Total   Spent    Left
Speed
100  945k  100  945k    0     0   314k      0  0:00:03  0:00:03 --:--:--
 314k
ruru 4.11 $ tar Jxf rtems-source-builder-4.11.2-rc3.tar.xz
ruru 4.11 $ cd rtems-source-builder-4.11.2-rc3/rtems
ruru rtems $ ../source-builder/sb-set-builder
--prefix=/opt/work/rtems/4.11 --log=x.txt 4.11/rtems-arm
RTEMS Source Builder - Set Builder, 4.11.2-rc3
Build Set: 4.11/rtems-arm
Build Set: 4.11/rtems-autotools.bset
Build Set: 4.11/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-freebsd11.0-1
Creating source directory: sources
download:
https://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc3/sources/autoconf-2.69.tar.gz
-> sources/autoconf-2.69.tar.gz
downloading: sources/autoconf-2.69.tar.gz - 1.8MB of 1.8MB (100%)
building: autoconf-2.69-x86_64-freebsd11.0-1
^CBuild Set: Time 0:00:05.408384
Build Set: Time 0:00:05.409491
Build Set: Time 0:00:05.412494
abort: user terminated
And with python3:
ruru rtems $ rm sources/*
ruru rtems $ python3 ../source-builder/sb-set-builder
download:
downloading: sources/autoconf-2.69.tar.gz - 768.0kB of 1.8MB (41%) ^C
download:
https://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc3/sources/autoconf-2.69.tar.gz:
error
download:
error
Build Set: Time 0:00:06.209305
Build Set: Time 0:00:06.210446
Build Set: Time 0:00:06.213511
And on OSX:
huia:releases chris$ curl -o rtems-source-builder-4.11.2-rc3.tar.xz
Current
Speed
100  945k  100  945k    0     0   291k      0  0:00:03  0:00:03 --:--:--
 291k
huia:releases chris$ tar Jxf rtems-source-builder-4.11.2-rc3.tar.xz
huia:releases chris$ cd rtems-source-builder-4.11.2-rc3/rtems/
huia:rtems chris$ ../source-builder/sb-set-builder --no-install
package: autoconf-2.69-x86_64-apple-darwin16.5.0-1
download:
building: autoconf-2.69-x86_64-apple-darwin16.5.0-1
^CBuild Set: Time 0:00:08.126000
Build Set: Time 0:00:08.126978
Build Set: Time 0:00:08.129516
