RTEMS 4.11.2-rc3 Release
Needell, Jerry Jerry.Needell at unh.edu
Sun Apr 9 13:47:13 UTC 2017
It looks like I am using python 2.7.5 - I can try it again with python3.
I’m not sure what your examples below are showing.  I looks like you aborted them after the first successful download of the autoconf tools.
In my trial the first several download/build phases worked fine. It was not until it got to rtems-tools that it failed.
I just looked like at at that point, it lost the “rc” from the search path.
> On Apr 8, 2017, at 7:29 PM, Chris Johns <chrisj at rtems.org> wrote:
> On 9/4/17 8:18 am, Chris Johns wrote:
>> The VERSION INI file that is embedded in the RC's RSB package should
>> contain a `release_url` key/value pair that points to the RC sources on
>> ftp.rtems.org using the https protocol.
>> This raises a couple of questions, there is still a bug in the get_file
>> function in download.py, and why do I not see this on FreeBSD yet you
>> see it on CentOS7?
> Are you using Python3? Python3 is working for me on FreeBSD.
> The following is running on FreeBSD:
> ruru 4.11 $ curl -o rtems-source-builder-4.11.2-rc3.tar.xz
> https://urldefense.proofpoint.com/v2/url?u=https-3A__ftp.rtems.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_rtems-2Dsource-2Dbuilder-2D4.11.2-2Drc3.tar.xz&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=V9PHHtqU_Ji9DqDDyy2R3Qfz3W-2acnkhW3tR8Pt1vE&e=
>  % Total    % Received % Xferd  Average Speed   Time    Time     Time
> Current
>                                 Dload  Upload   Total   Spent    Left
> Speed
> 100  945k  100  945k    0     0   314k      0  0:00:03  0:00:03 --:--:--
> 314k
> ruru 4.11 $ tar Jxf rtems-source-builder-4.11.2-rc3.tar.xz
> ruru 4.11 $ cd rtems-source-builder-4.11.2-rc3/rtems
> ruru rtems $ ../source-builder/sb-set-builder
> --prefix=/opt/work/rtems/4.11 --log=x.txt 4.11/rtems-arm
> RTEMS Source Builder - Set Builder, 4.11.2-rc3
> Build Set: 4.11/rtems-arm
> Build Set: 4.11/rtems-autotools.bset
> Build Set: 4.11/rtems-autotools-internal.bset
> config: tools/rtems-autoconf-2.69-1.cfg
> package: autoconf-2.69-x86_64-freebsd11.0-1
> Creating source directory: sources
> download:
> https://urldefense.proofpoint.com/v2/url?u=https-3A__ftp.rtems.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_sources_autoconf-2D2.69.tar.gz&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=vfEvq_qT-FoLJOMOqW0vv09LxNOVCpYt7qv5yAv3YTc&e=
> -> sources/autoconf-2.69.tar.gz
> downloading: sources/autoconf-2.69.tar.gz - 1.8MB of 1.8MB (100%)
> building: autoconf-2.69-x86_64-freebsd11.0-1
> ^CBuild Set: Time 0:00:05.408384
> Build Set: Time 0:00:05.409491
> Build Set: Time 0:00:05.412494
> abort: user terminated
> And with python3:
> ruru rtems $ rm sources/*
> ruru rtems $ python3 ../source-builder/sb-set-builder
> download:
> downloading: sources/autoconf-2.69.tar.gz - 768.0kB of 1.8MB (41%) ^C
> download:
> https://urldefense.proofpoint.com/v2/url?u=https-3A__ftp.rtems.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_sources_autoconf-2D2.69.tar.gz-3A&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=XqWn4NqF941OdUy1N5clcqwQo8nxlAReRw69wLZisJI&e=
> error
> download:
> error
> Build Set: Time 0:00:06.209305
> Build Set: Time 0:00:06.210446
> Build Set: Time 0:00:06.213511
> And on OSX:
> huia:releases chris$ curl -o rtems-source-builder-4.11.2-rc3.tar.xz
> Current
> Speed
> 100  945k  100  945k    0     0   291k      0  0:00:03  0:00:03 --:--:--
> 291k
> huia:releases chris$ tar Jxf rtems-source-builder-4.11.2-rc3.tar.xz
> huia:releases chris$ cd rtems-source-builder-4.11.2-rc3/rtems/
> huia:rtems chris$ ../source-builder/sb-set-builder --no-install
> package: autoconf-2.69-x86_64-apple-darwin16.5.0-1
> download:
> building: autoconf-2.69-x86_64-apple-darwin16.5.0-1
> ^CBuild Set: Time 0:00:08.126000
> Build Set: Time 0:00:08.126978
> Build Set: Time 0:00:08.129516
> Chris
> users mailing list
> users at rtems.org
> https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rtems.org_mailman_listinfo_users&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=73IyA2Tz5fAxGmytPuWZ2bjTImhzcvKNEZc0W-ptetU&e=
