RTEMS 4.11.0 build fails on Windows
Linda Huxley lhuxley at shaw.ca
Tue Apr 11 01:02:19 UTC 2017
Thanks Worth,
Your second patch doesn't look right.  It appears to apply a floating
point patch specific to an ARM processor.  (I'm building for a SPARK
processor, but only because that's what's recommended for newbies.  I
don't see any ARM or SPARK specific build files in my build tree at all.)
So instead of that patch, I manually added the following text:
%patch add newlib
file:///c/opt/rtems/4.11.0/rtems/gcc-4.9.3-20170404-1.patch
%hash md5 gcc-4.9.3-20170404-1.patch 3204f732cb2ec7a8dff8b7f3463e9262
in the most obvious location in the following file:
/c/opt/rtems/4.11.0/rtems/config/tools/
     rtems-gcc-4.9.3-newlib-2.2.0-20150423-1.cfg
That was the only file that I found that closely resembles the name of
the file patched by your second patch.  The build now fails while
processing your first patch.  The pertinent log entries follow at the
bottom of my reply.
My build directory tree doesn't appear to match yours.  The particular
directory tree that I have would seem to be a consequence of following
the instructions in chapter 5 of the RTEMS User Manual.  I have also
attempted to build from various other recipes on the RTEMS website, (all
unsuccessfully), and I have noted that different build directory trees
that have resulted.
At present, I don't have an "rsb" sub-directory anywhere, and I am
building from here:
The problematic file, cfns.gperf, is here:
/c/opt/rtems/4.11.0/rtems/build/srg4n2xwm1/gcc-4.9.3/gcc/cp/cfns.gperf
I'm not sure how to modify your patch file to process that file.  I have
almost no experience with Linux or MINGW so I'm at a bit of a loss at
this point.
Can you perhaps suggest what I need to do to modify your patch file?
Regards,
Linda
+ cd newlib-2.2.0.20150423
+ chmod -R a+rX,g-w,o-w .
+ cat /C/opt/rtems/4.11.0/rtems/patches/gcc-4.9.3-20170404-1.patch
+ patch -p1
can't find file to patch at input line 4
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff -Naur gcc-4.9.3-orig/gcc/cp/cfns.gperf
gcc-4.9.3-fixed/gcc/cp/cfns.gperf
|--- gcc-4.9.3-orig/gcc/cp/cfns.gperf    2014-01-02 17:23:26.000000000 -0500
|+++ gcc-4.9.3-fixed/gcc/cp/cfns.gperf    2017-04-04 14:35:14.729966600
-0400
File to patch:
Skip this patch? [y]
Skipping patch.
2 out of 2 hunks ignored
can't find file to patch at input line 28
|diff -Naur gcc-4.9.3-orig/gcc/cp/cfns.h gcc-4.9.3-fixed/gcc/cp/cfns.h
|--- gcc-4.9.3-orig/gcc/cp/cfns.h    2014-01-02 17:23:26.000000000 -0500
|+++ gcc-4.9.3-fixed/gcc/cp/cfns.h    2017-04-04 14:35:14.729966600 -0400
File to patch:
Skipping patch.
4 out of 4 hunks ignored
can't find file to patch at input line 100
|diff -Naur gcc-4.9.3-orig/gcc/cp/except.c gcc-4.9.3-fixed/gcc/cp/except.c
|--- gcc-4.9.3-orig/gcc/cp/except.c    2014-01-02 17:23:26.000000000 -0500
|+++ gcc-4.9.3-fixed/gcc/cp/except.c    2017-04-04 14:35:14.729966600 -0400
File to patch:
Skipping patch.
1 out of 1 hunk ignored
can't find file to patch at input line 113
|diff -Naur gcc-4.9.3-orig/gcc/cp/Make-lang.in
gcc-4.9.3-fixed/gcc/cp/Make-lang.in
|--- gcc-4.9.3-orig/gcc/cp/Make-lang.in    2014-04-15 04:04:17.000000000
-0400
|+++ gcc-4.9.3-fixed/gcc/cp/Make-lang.in    2017-04-04
14:37:24.515417000 -0400
File to patch:
Skipping patch.
shell cmd failed: sh -ex  /C/opt/rtems/4.11.0/rtems/build/srg4n2xwm1/doit
error: building srg4n2xwm1
On 2017-04-10 08:02, Worth Burruss wrote:
 > Linda,
 > What you are seeing is caused by a recent upgrade of gcc in the MSYS2
enviornment.  A few
 > months ago it was 5.something and now it is 6.something.  I came
across this last week in
 > setting up a new machine.  I found a patch from the GCC mailing list
for 5.something and
 > adjusted it for gcc 4.9.3.
 > Attached are the 2 patches I created and put in a temp area to come
back to latter and
 > properly fix when I had time.  I have never applied them to another
system, but am pretty
 > sure they should work.  The gcc patch file goes in your
rsb/rtems/patches directory and the
 > rsb will do the patch application.  the other patch you have to appy
with:
 > patch -p1 < rsb-fix-for-gcc-4.11-2017-0405-1.patch
 > with -p1 depending on where you put the patch, I can not remeber for
sure but think this
 > would be the top level rsb directory.
 > Unfortunatly I do not have time for the next 2 or 3 weeks to actualy
look into fixing the
 > patches properly so issues still exist, you will definitly get a
warning about no checksum for
 > the gcc patch file, but it will not stop the build.  I suspect others
may exist such as carriage
 > return / line feeds.
 > Hopefully this is enough to get you started.
 > Thank you,
 > Worth Burruss
