RTEMS 4.11.0 build fails on Windows
Linda Huxley lhuxley at shaw.ca
Wed Apr 12 00:16:17 UTC 2017
> Also if you have any suggestions on how I can improve the documentation
> please let me know.
Thanks Chris,
There are a couple of typos in section "5.2.1. RTEMS Tools and Kernel"
of the "RTEMS User Manual" 4.11.99:
$ mv rtems-source-builder-4.11.0 4.110
$ cd 4.11.0
That should read:
$ mv rtems-source-builder-4.11.0 4.11.0
$ cd 4.11.0/rtems
I wasted quite a bit of time because of the omission on the second line.
I also wasted time with section "3. Quick Start".  The instructions
there don't seem to apply to Windows users.  I would have done much
better just jumping directly to section 5.2.1, after reading parts of
chapter 4.
I also wasted time with "5.1.1 Project Sandboxing".  That might be
helpful once I have something working, but it was no help while getting
started.  I tried to follow one of the schemes mentioned there, but then
I found that RSB refused to make use of my directory tree anyways.
Regards,
Linda
