Doubt about interrupts in xilinx zedboard BSP
Sergio Paracuellos
sparacuellos at orbitalcs.com
Tue Apr 18 08:11:26 UTC 2017
2017-04-18 9:28 GMT+02:00 Thomas Doerfler <
thomas.doerfler at embedded-brains.de>:
> Hi,
Hi,
> what kind of interrupt source do you have? I assume that the intterrupt
> source keeps it interrupt request active, until you have done something
> in the interrupt source registers that makes the interrupt inactive again.
The interrupt is a Software Generated Interrupt one which uses SGI0 HW IRQ.
The interrupt pending bit for the vector is being cleared in
bsp_interrupt_dispatch() routine for the arm's based bsp's.
It should be enough to get this working, but it seems it is not. Something
that I have to keep in mind?
> Example: If you interrupt source is a UART receiver, the interrupt
> request usually stays active until you have pulled all the received UART
> bytes from the UART receive data register...
> wkr,
> Thomas.
Cheers,
Sergio Paracuellos
> Am 18.04.2017 um 09:24 schrieb Sergio Paracuellos:
> > Hi all,
> > I am trying to exec some code over xilinx-zynq zedboard. The code tries
> > to make use of interrupts. I am installing the interrupt routine for the
> > interrupt vector using rtems_interrupt_handler_install routine which is
> > seems the correct one for this board. When the interrupt is trigered the
> > handler is correctly called but it becomes in a infinite loop status
> > when the interrupt is being handled. So is obvious that i am doing
> > something wrong. The pseudo code for this is like the following:
> > #include <bsp.h>
> > #include <stdlib.h>
> > #include <rtems/irq.h>
> > #include <rtems/irq-extension.h>
> > #define MAX_NUMBER_OF_MESSAGES 5
> > #define INTERRUPT_VECTOR_NUMBER 100
> > volatile int seq;
> > void MyInterruptHandler(void *arg)
> > puts("Interrupt handler called\n");
> > seq++;
> > rtems_task Init(rtems_task_argument argument)
> > rtems_status_code sc;
> > sc = rtems_interrupt_handler_install(
> > INTERRUPT_VECTOR_NUMBER,
> > "MY_INTERRUPT",
> > RTEMS_INTERRUPT_UNIQUE,
> > (rtems_interrupt_handler) MyInterruptHandler,
> > NULL
> > if (sc != RTEMS_SUCCESSFUL)
> > puts("MyInterruptHandler -> rtems_interrupt_handler_install()
> > error: %d\n", sc);
> > exit(-1);
> > puts("Waiting for messages...\n");
> > /* wait for five interrupts to be triggered */
> > while (1)
> > if (seq == MAX_NUMBER_OF_MESSAGES)
> > break;
> > puts("Max number of messages retrieved\n");
> > exit(0);
> > The result is:
> > Enters in a infinite loop calling the interrupt handler....
> > This similar code runs for me in other OS, so i am a little lost. Also,
> > I couldn't find any example of using interrupts for zedboard.
> > What is missing in this code?
> > Thanks in advance,
> > Cheers,
> > Sergio Paracuellos
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> embedded brains GmbH
> Thomas Doerfler
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: Thomas.Doerfler at embedded-brains.de
> Phone: +49-89-18 94 741-12
> Fax: +49-89-18 94 741-09
> PGP: Public key available on request.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170418/30914bcb/attachment-0001.html>
