Doubt about interrupts in xilinx zedboard BSP
Sergio Paracuellos
sparacuellos at orbitalcs.com
Wed Apr 19 07:33:16 UTC 2017
2017-04-19 8:12 GMT+02:00 Thomas Doerfler <Thomas.Doerfler at imd-systems.de>:
> Hello,
Hi,
> one short request from me: If you got the solution, please post a sketch
> of it here. It is good to have this list as a reference not only for
> problems, but also for solutions ;-)
No problem :-). I am still working on it.
Regards,
Sergio Paracuellos
> Kind regards,
> Thomas.
> Am 18.04.2017 um 10:54 schrieb Sergio Paracuellos:
> > 2017-04-18 10:15 GMT+02:00 Thomas Doerfler
> > <thomas.doerfler at embedded-brains.de
> > <mailto:thomas.doerfler at embedded-brains.de>>:
> > Hi,
> > Hi,
> > does this link help?
> > https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/
> Zynq-Clear-Pending-SGI/td-p/747038
> > <https://forums.xilinx.com/t5/Zynq-All-Programmable-SoC/
> Zynq-Clear-Pending-SGI/td-p/747038>
> > Of course it helps :) Thank you very much. I am going to check this.
> > wkr,
> > Thomas.
> > Cheers,
> > Sergio Paracuellos
> > Am 18.04.2017 um 10:11 schrieb Sergio Paracuellos:
> > > 2017-04-18 9:28 GMT+02:00 Thomas Doerfler
> > <mailto:thomas.doerfler at embedded-brains.de>>>:
> > > Hi,
> > > Hi,
> > > what kind of interrupt source do you have? I assume that the
> > intterrupt
> > > source keeps it interrupt request active, until you have done
> > something
> > > in the interrupt source registers that makes the interrupt
> > inactive
> > > again.
> > > The interrupt is a Software Generated Interrupt one which uses
> > SGI0 HW IRQ.
> > > The interrupt pending bit for the vector is being cleared in
> > > bsp_interrupt_dispatch() routine for the arm's based bsp's.
> > > It should be enough to get this working, but it seems it is not.
> > > Something that I have to keep in mind?
> > > Example: If you interrupt source is a UART receiver, the
> interrupt
> > > request usually stays active until you have pulled all the
> > received UART
> > > bytes from the UART receive data register...
> > > wkr,
> > > Thomas.
> > > Cheers,
> > > Sergio Paracuellos
> > > Am 18.04.2017 um 09:24 schrieb Sergio Paracuellos:
> > > > Hi all,
> > > > I am trying to exec some code over xilinx-zynq zedboard. The
> > code
> > > tries
> > > > to make use of interrupts. I am installing the interrupt
> routine
> > > for the
> > > > interrupt vector using rtems_interrupt_handler_install
> routine
> > > which is
> > > > seems the correct one for this board. When the interrupt is
> > > trigered the
> > > > handler is correctly called but it becomes in a infinite
> > loop status
> > > > when the interrupt is being handled. So is obvious that i am
> > doing
> > > > something wrong. The pseudo code for this is like the
> following:
> > > > #include <bsp.h>
> > > > #include <stdlib.h>
> > > > #include <rtems/irq.h>
> > > > #include <rtems/irq-extension.h>
> > > > #define MAX_NUMBER_OF_MESSAGES 5
> > > > #define INTERRUPT_VECTOR_NUMBER 100
> > > > volatile int seq;
> > > > void MyInterruptHandler(void *arg)
> > > > puts("Interrupt handler called\n");
> > > > seq++;
> > > > rtems_task Init(rtems_task_argument argument)
> > > > rtems_status_code sc;
> > > > sc = rtems_interrupt_handler_install(
> > > > INTERRUPT_VECTOR_NUMBER,
> > > > "MY_INTERRUPT",
> > > > RTEMS_INTERRUPT_UNIQUE,
> > > > (rtems_interrupt_handler)
> > > MyInterruptHandler,
> > > > NULL
> > > > if (sc != RTEMS_SUCCESSFUL)
> > > > puts("MyInterruptHandler ->
> > > rtems_interrupt_handler_install()
> > > > error: %d\n", sc);
> > > > exit(-1);
> > > > puts("Waiting for messages...\n");
> > > > /* wait for five interrupts to be triggered */
> > > > while (1)
> > > > if (seq == MAX_NUMBER_OF_MESSAGES)
> > > > break;
> > > > puts("Max number of messages retrieved\n");
> > > > exit(0);
> > > > The result is:
> > > > Enters in a infinite loop calling the interrupt handler....
> > > > This similar code runs for me in other OS, so i am a little
> > lost.
> > > Also,
> > > > I couldn't find any example of using interrupts for zedboard.
> > > > What is missing in this code?
> > > > Thanks in advance,
> > > > Cheers,
> > > > Sergio Paracuellos
> > > > _______________________________________________
> > > > users mailing list
> > > > users at rtems.org <mailto:users at rtems.org>
> > <mailto:users at rtems.org <mailto:users at rtems.org>>
> > > > http://lists.rtems.org/mailman/listinfo/users
> > <http://lists.rtems.org/mailman/listinfo/users>
> > <http://lists.rtems.org/mailman/listinfo/users>>
> > > embedded brains GmbH
> > > Thomas Doerfler
> > > Dornierstr. 4
> > > D-82178 Puchheim
> > > Germany
> > > email: Thomas.Doerfler at embedded-brains.de
> > <mailto:Thomas.Doerfler at embedded-brains.de>
> > <mailto:Thomas.Doerfler at embedded-brains.de>>
> > > Phone: +49-89-18 94 741-12 <tel:%2B49-89-18%2094%20741-12>
> > > Fax: +49-89-18 94 741-09 <tel:%2B49-89-18%2094%20741-09>
> > > PGP: Public key available on request.
> > > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne
> des EHUG.
> > > users mailing list
> > Thomas Doerfler
> > Dornierstr. 4
> > D-82178 Puchheim
> > Germany
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> > users mailing list
> > users at rtems.org
> IMD Ingenieurbuero fuer Microcomputertechnik
> Thomas Doerfler Herbststrasse 8
> D-82178 Puchheim Germany
> email: Thomas.Doerfler at imd-systems.de
> PGP public key available on request
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170419/a843fb6e/attachment-0001.html>
