RSB 4.11.2-rc4 rtems-arm build fails on Windows
Linda Huxley lhuxley at shaw.ca
Thu Apr 20 09:42:26 UTC 2017
Hi Chris,
After 3 other attempts, I did a clean build of the ARM version of RTEMS
on Windows, using the following commands:
$ cd /c
$ mkdir -p opt/rtems
$ cd opt/rtems
$ wget
https://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc4/rtems-source-builder-4.11.2-rc4.tar.xz
$ tar Jxf rtems-source-builder-4.11.2-rc4.tar.xz
$ mv rtems-source-builder-4.11.2-rc4 r4.11.2
$ cd r4.11.2/rtems/
$ ../source-builder/sb-set-builder --prefix=/c/opt/rtems/4.11
4.11/rtems-arm --jobs=none
The build fails with the following trace, much like the SPARC build
failed before applying the patch provided by Worth Burruss.
error: building arg4n2xwm1
Build FAILED
   See error report:
rsb-report-arm-rtems4.11-gcc-4.9.3-newlib-2.2.0.20150423-x86_64-w64-mingw32-1.txt
Build Set: Time 0:36:57.587859
Build FAILED
The salient error messages at the bottom of the error report are:
In file included from ../../gcc-4.9.3/gcc/cp/except.c:1013:0:
cfns.gperf: In function 'const char* libc_name_p(const char*, unsigned
int)':
cfns.gperf:101:1: error: 'const char* libc_name_p(const char*, unsigned
int)' redeclared inline with 'gnu_inline' attribute
cfns.gperf:26:14: note: 'const char* libc_name_p(const char*, unsigned
int)' previously declared here
Is it possible that RTEMS 4.11.2-rc4 does not apply Worth's patch when
building the ARM version of RTEMS?
When I look in:
/c/opt/rtems/r4.11.2/rtems/patches
I only see the following patch files:
automake-1.12.6-bugzilla.redhat.com-1239379.diff
binutils-2.26-gas-reloc.patch
newlib-ARM-Optimize-IEEE-754-sqrt-implementation.diff
I do not see Worth's patch file anywhere:
gcc-4.9.3-20170404-1.patch
(In the mean time, I was able to build the i386 version of RTEMS, build
an example RTEMS program then boot it and run it using VirtualBox.)
Regards,
Linda
