RTEMS 4.11.2-rc3 Release
Sun Apr 9 20:36:28 UTC 2017
On Sun, Apr 9, 2017 at 8:47 AM, Needell, Jerry <Jerry.Needell at unh.edu>
wrote:
> It looks like I am using python 2.7.5 - I can try it again with python3
$ python --version
Python 2.7.5
It was the same on my local VM and the server I used for all my RTEMS
testing.
So that's not the culprit.
I’m not sure what your examples below are showing.  I looks like you
> aborted them after the first successful download of the autoconf tools.
> In my trial the first several download/build phases worked fine. It was
> not until it got to rtems-tools that it failed.
> I just looked like at at that point, it lost the “rc” from the search path.
> I apparently haven't tried this rc yet.  But looking in the rc1 tools
build log, I see this:
download:
ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc1/rtems-tools-4.11.2-rc1.tar.xz
-> sources/rtems-tools-4.11.2-rc1.tar.xz
^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 0.0 bytes of 1.6MB
(0%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 256.0kB of
1.6MB (15%)  ^H^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz -
512.0kB of 1.6MB (30%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz
- 768.0kB of 1.6MB (46%) ^Mdownloading:
sources/rtems-tools-4.11.2-rc1.tar.xz - 1.0MB of 1.6MB (61%)
^H^H^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 1.2MB of 1.6MB
(76%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 1.5MB of 1.6MB
(92%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 1.6MB of 1.6MB
(100%)
^Mbuilding: rtems-tools-4.11.2-rc1-1
reporting: tools/rtems-tools-4.11-1.cfg -> rtems-tools-4.11.2-rc1-1.txt
reporting: tools/rtems-tools-4.11-1.cfg -> rtems-tools-4.11.2-rc1-1.xml
config: tools/rtems-kernel-4.11.cfg
package: sparc-rtems4.11-kernel-4.11.2-rc1-1
download:
ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc1/rtems-4.11.2-rc1.tar.xz
-> sources/rtems-4.11.2-rc1.tar.xz
--joel
> > On Apr 8, 2017, at 7:29 PM, Chris Johns <chrisj at rtems.org> wrote:
> > On 9/4/17 8:18 am, Chris Johns wrote:
> >> The VERSION INI file that is embedded in the RC's RSB package should
> >> contain a `release_url` key/value pair that points to the RC sources on
> >> ftp.rtems.org using the https protocol.
> >> This raises a couple of questions, there is still a bug in the get_file
> >> function in download.py, and why do I not see this on FreeBSD yet you
> >> see it on CentOS7?
> > Are you using Python3? Python3 is working for me on FreeBSD.
> > The following is running on FreeBSD:
> > ruru 4.11 $ curl -o rtems-source-builder-4.11.2-rc3.tar.xz
> > https://urldefense.proofpoint.com/v2/url?u=https-3A__ftp.
> rtems.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_rtems-
> 2Dsource-2Dbuilder-2D4.11.2-2Drc3.tar.xz&d=DwICAg&c=
> c6MrceVCY5m5A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-
> TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=V9PHHtqU_Ji9DqDDyy2R3Qfz3W-
> 2acnkhW3tR8Pt1vE&e=
> >  % Total    % Received % Xferd  Average Speed   Time    Time     Time
> > Current
> >                                 Dload  Upload   Total   Spent    Left
> > Speed
> > 100  945k  100  945k    0     0   314k      0  0:00:03  0:00:03 --:--:--
> > 314k
> > ruru 4.11 $ tar Jxf rtems-source-builder-4.11.2-rc3.tar.xz
> > ruru 4.11 $ cd rtems-source-builder-4.11.2-rc3/rtems
> > ruru rtems $ ../source-builder/sb-set-builder
> > --prefix=/opt/work/rtems/4.11 --log=x.txt 4.11/rtems-arm
> > RTEMS Source Builder - Set Builder, 4.11.2-rc3
> > Build Set: 4.11/rtems-arm
> > Build Set: 4.11/rtems-autotools.bset
> > Build Set: 4.11/rtems-autotools-internal.bset
> > config: tools/rtems-autoconf-2.69-1.cfg
> > package: autoconf-2.69-x86_64-freebsd11.0-1
> > Creating source directory: sources
> > download:
> rtems.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_sources_
> autoconf-2D2.69.tar.gz&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=
> TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=vfEvq_qT-
> FoLJOMOqW0vv09LxNOVCpYt7qv5yAv3YTc&e=
> > -> sources/autoconf-2.69.tar.gz
> > downloading: sources/autoconf-2.69.tar.gz - 1.8MB of 1.8MB (100%)
> > building: autoconf-2.69-x86_64-freebsd11.0-1
> > ^CBuild Set: Time 0:00:05.408384
> > Build Set: Time 0:00:05.409491
> > Build Set: Time 0:00:05.412494
> > abort: user terminated
> > And with python3:
> > ruru rtems $ rm sources/*
> > ruru rtems $ python3 ../source-builder/sb-set-builder
> > download:
> > downloading: sources/autoconf-2.69.tar.gz - 768.0kB of 1.8MB (41%) ^C
> > download:
> autoconf-2D2.69.tar.gz-3A&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=
> TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=XqWn4NqF941OdUy1N5clcqwQo8nxlA
> ReRw69wLZisJI&e=
> > error
> > download:
> ReRw69wLZisJI&e=
> > error
> > Build Set: Time 0:00:06.209305
> > Build Set: Time 0:00:06.210446
> > Build Set: Time 0:00:06.213511
> > And on OSX:
> > huia:releases chris$ curl -o rtems-source-builder-4.11.2-rc3.tar.xz
> 2acnkhW3tR8Pt1vE&e=
> > Current
> > Speed
> > 100  945k  100  945k    0     0   291k      0  0:00:03  0:00:03 --:--:--
> > 291k
> > huia:releases chris$ tar Jxf rtems-source-builder-4.11.2-rc3.tar.xz
> > huia:releases chris$ cd rtems-source-builder-4.11.2-rc3/rtems/
> > huia:rtems chris$ ../source-builder/sb-set-builder --no-install
> > package: autoconf-2.69-x86_64-apple-darwin16.5.0-1
> > download:
> > building: autoconf-2.69-x86_64-apple-darwin16.5.0-1
> > ^CBuild Set: Time 0:00:08.126000
> > Build Set: Time 0:00:08.126978
> > Build Set: Time 0:00:08.129516
> > Chris
> > users mailing list
> > users at rtems.org
> > https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.
> rtems.org_mailman_listinfo_users&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=
> TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=73IyA2Tz5fAxGmytPuWZ2bjTImhzcv
> KNEZc0W-ptetU&e=
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170409/93d68ca8/attachment-0002.html>
