RTEMS 4.11.2-rc3 Release
Sun Apr 9 20:57:03 UTC 2017
FWIW I just started an rc3 build and I think I have the same issue as Jerry.
This is on rtbf64c and rc1 built find.
config: tools/rtems-tools-4.11-1.cfg
package: rtems-tools-4.11.2-rc3-1
download:
ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc3/rtems-tools-4.11.2-rc3.tar.xz
-> sources/rtems-tools-4.11.2-rc3.tar.xz
download:
ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc3/rtems-tools-4.11.2-rc3.tar.xz:
error: <urlopen error ftp error: 550 Failed to change directory.>
error: downloading
all paths have failed, giving up
Build FAILED
  See error report: rsb-report-rtems-tools-4.11.2-rc3-1.txt
error: downloading
Build Set: Time 0:17:03.301321
Build FAILED
The path is wrong. It should be using this directory:
ftp://ftp.rtems.org/pub/rtems/releases/4.11/rc/4.11.2-rc3/
The /rc/ component is missing.
I hope I am not repeating something Jerry tried to make clear. :)
--joel
On Sun, Apr 9, 2017 at 3:36 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Apr 9, 2017 at 8:47 AM, Needell, Jerry <Jerry.Needell at unh.edu>
> wrote:
>> It looks like I am using python 2.7.5 - I can try it again with python3
> $ python --version
> Python 2.7.5
> It was the same on my local VM and the server I used for all my RTEMS
> testing.
> So that's not the culprit.
> I’m not sure what your examples below are showing.  I looks like you
>> aborted them after the first successful download of the autoconf tools.
>> In my trial the first several download/build phases worked fine. It was
>> not until it got to rtems-tools that it failed.
>> I just looked like at at that point, it lost the “rc” from the search
>> path.
>> I apparently haven't tried this rc yet.  But looking in the rc1 tools
> build log, I see this:
> download: ftp://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2-rc1/
> rtems-tools-4.11.2-rc1.tar.xz -> sources/rtems-tools-4.11.2-rc1.tar.xz
> ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 0.0 bytes of 1.6MB
> (0%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz - 256.0kB of
> 1.6MB (15%)  ^H^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz -
> 512.0kB of 1.6MB (30%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz
> - 768.0kB of 1.6MB (46%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz
> - 1.0MB of 1.6MB (61%)   ^H^H^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz
> - 1.2MB of 1.6MB (76%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz
> - 1.5MB of 1.6MB (92%) ^Mdownloading: sources/rtems-tools-4.11.2-rc1.tar.xz
> - 1.6MB of 1.6MB (100%)
> ^Mbuilding: rtems-tools-4.11.2-rc1-1
> reporting: tools/rtems-tools-4.11-1.cfg -> rtems-tools-4.11.2-rc1-1.txt
> reporting: tools/rtems-tools-4.11-1.cfg -> rtems-tools-4.11.2-rc1-1.xml
> config: tools/rtems-kernel-4.11.cfg
> package: sparc-rtems4.11-kernel-4.11.2-rc1-1
> rtems-4.11.2-rc1.tar.xz -> sources/rtems-4.11.2-rc1.tar.xz
> --joel
>> > On Apr 8, 2017, at 7:29 PM, Chris Johns <chrisj at rtems.org> wrote:
>> > On 9/4/17 8:18 am, Chris Johns wrote:
>> >> The VERSION INI file that is embedded in the RC's RSB package should
>> >> contain a `release_url` key/value pair that points to the RC sources on
>> >> ftp.rtems.org using the https protocol.
>> >> This raises a couple of questions, there is still a bug in the get_file
>> >> function in download.py, and why do I not see this on FreeBSD yet you
>> >> see it on CentOS7?
>> > Are you using Python3? Python3 is working for me on FreeBSD.
>> > The following is running on FreeBSD:
>> > ruru 4.11 $ curl -o rtems-source-builder-4.11.2-rc3.tar.xz
>> > https://urldefense.proofpoint.com/v2/url?u=https-3A__ftp.rte
>> ms.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_rtems-2Dsou
>> rce-2Dbuilder-2D4.11.2-2Drc3.tar.xz&d=DwICAg&c=c6MrceVCY5m5
>> A_KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=
>> h-TgtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=V9PHHtqU_Ji9Dq
>> DDyy2R3Qfz3W-2acnkhW3tR8Pt1vE&e=
>> >  % Total    % Received % Xferd  Average Speed   Time    Time     Time
>> > Current
>> >                                 Dload  Upload   Total   Spent    Left
>> > Speed
>> > 100  945k  100  945k    0     0   314k      0  0:00:03  0:00:03 --:--:--
>> > 314k
>> > ruru 4.11 $ tar Jxf rtems-source-builder-4.11.2-rc3.tar.xz
>> > ruru 4.11 $ cd rtems-source-builder-4.11.2-rc3/rtems
>> > ruru rtems $ ../source-builder/sb-set-builder
>> > --prefix=/opt/work/rtems/4.11 --log=x.txt 4.11/rtems-arm
>> > RTEMS Source Builder - Set Builder, 4.11.2-rc3
>> > Build Set: 4.11/rtems-arm
>> > Build Set: 4.11/rtems-autotools.bset
>> > Build Set: 4.11/rtems-autotools-internal.bset
>> > config: tools/rtems-autoconf-2.69-1.cfg
>> > package: autoconf-2.69-x86_64-freebsd11.0-1
>> > Creating source directory: sources
>> > download:
>> ms.org_pub_rtems_releases_4.11_rc_4.11.2-2Drc3_sources_aut
>> oconf-2D2.69.tar.gz&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=WPT
>> 82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-TgtwoBBHIM2be95
>> TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=vfEvq_qT-FoLJOMOqW0vv09LxNOVCp
>> Yt7qv5yAv3YTc&e=
>> > -> sources/autoconf-2.69.tar.gz
>> > downloading: sources/autoconf-2.69.tar.gz - 1.8MB of 1.8MB (100%)
>> > building: autoconf-2.69-x86_64-freebsd11.0-1
>> > ^CBuild Set: Time 0:00:05.408384
>> > Build Set: Time 0:00:05.409491
>> > Build Set: Time 0:00:05.412494
>> > abort: user terminated
>> > And with python3:
>> > ruru rtems $ rm sources/*
>> > ruru rtems $ python3 ../source-builder/sb-set-builder
>> > download:
>> Yt7qv5yAv3YTc&e=
>> > downloading: sources/autoconf-2.69.tar.gz - 768.0kB of 1.8MB (41%) ^C
>> > download:
>> oconf-2D2.69.tar.gz-3A&d=DwICAg&c=c6MrceVCY5m5A_KAUkrdoA&r=W
>> PT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-TgtwoBBHIM2be
>> 95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=XqWn4NqF941OdUy1N5clcqwQo8nx
>> lAReRw69wLZisJI&e=
>> > error
>> > download:
>> lAReRw69wLZisJI&e=
>> > error
>> > Build Set: Time 0:00:06.209305
>> > Build Set: Time 0:00:06.210446
>> > Build Set: Time 0:00:06.213511
>> > And on OSX:
>> > huia:releases chris$ curl -o rtems-source-builder-4.11.2-rc3.tar.xz
>> > Current
>> > Speed
>> > 100  945k  100  945k    0     0   291k      0  0:00:03  0:00:03 --:--:--
>> > 291k
>> > huia:releases chris$ tar Jxf rtems-source-builder-4.11.2-rc3.tar.xz
>> > huia:releases chris$ cd rtems-source-builder-4.11.2-rc3/rtems/
>> > huia:rtems chris$ ../source-builder/sb-set-builder --no-install
>> > package: autoconf-2.69-x86_64-apple-darwin16.5.0-1
>> > download:
>> Yt7qv5yAv3YTc&e=
>> > building: autoconf-2.69-x86_64-apple-darwin16.5.0-1
>> > ^CBuild Set: Time 0:00:08.126000
>> > Build Set: Time 0:00:08.126978
>> > Build Set: Time 0:00:08.129516
>> > Chris
>> > _______________________________________________
>> > users mailing list
>> > users at rtems.org
>> > https://urldefense.proofpoint.com/v2/url?u=http-3A__lists.rt
>> ems.org_mailman_listinfo_users&d=DwICAg&c=c6MrceVCY5m5A_
>> KAUkrdoA&r=WPT82bAHlIno0YYjFrFTmdTbUkDri435RAhnn916ixU&m=h-T
>> gtwoBBHIM2be95TPpEQVH5qk7iHE-_8Q7dJ3d40U&s=73IyA2Tz5fAxGmytP
>> uWZ2bjTImhzcvKNEZc0W-ptetU&e=
>> users mailing list
>> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170409/bbf65e81/attachment-0002.html>
