LEON2 and C++ exception handling
Mike Looijmans mike.looijmans at topic.nl
Mon Aug 14 06:04:22 UTC 2017
On 12-08-17 03:29, Chris Johns wrote:
> On 11/8/17 10:14 pm, Mike Looijmans wrote:
>> Is there maybe some other
>> entry/register/variable that my boot code needs to pass to RTEMS?
> Exceptions need valid tables registered with the unwinder to work or you end up
> in the terminate call.
> The SPARC architecture uses what is normally named dwarf2 tables that GCC places
> in '.eh_frame' or '.gcc_except_table.*' sections. The tables linked into the
> executable are registered with the exception handler code in libgcc and for C++
> are processed using '__gcc_personality_v0' personality function. I cannot
> remember how they are registered by default.
> I hope this helps.
Well, if I understand correctly, this just means that exception handling on
LEON2 is just not implemented in RTEMS.
Kind regards,
Mike Looijmans
System Expert
TOPIC Products
Materiaalweg 4, NL-5681 RJ Best
Postbus 440, NL-5680 AK Best
Telefoon: +31 (0) 499 33 69 79
E-mail: mike.looijmans at topicproducts.com
Website: www.topicproducts.com
Please consider the environment before printing this e-mail
