RTEMS 4.11.2 building troubles on Windows10
Mon Dec 18 21:54:28 UTC 2017
Please try sb-set-builder command again from the rtems directory of
the rtems-source-builder, i.e.:
cd rtems-source-builder/rtems
../source-builder/sb-set-builder --list-bsets
../source-builder/sb-set-builder --prefix=/opt/rtems/4.11 4.11/rtems-arm
On Mon, Dec 18, 2017 at 3:46 AM, 茂呂 智志 <s_moro at aes.co.jp> wrote:
> Hello all,
> I’m attempting to build the RTEMS tool set
> following “RTEMS User Manual” amd “RTEMS Source Builder” on Windows10,
> MinGW64.exe.
> I have done following commands,
> cd /c
> mkdir -p opt/rtems
> cd opt/rtems
> wget
> https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2/rtems-source-builder-4.11.2.tar.xz
> tar -Jxvf rtems-source-builder-4.11.2.tar.xz
> mv rtems-source-builder-4.11.2 4.11.2
> cd 4.11.2
> I have 2 troubles.
> Then, I have done following command,
> ./rtems-source-builder/sb-check --jobs=none
> Result,
> RTEMS Source Builder -Set Builder, 4.11.not_released
> Environment is ok
> What dose “4.11.not_released” mean and is the cause of “4.11.not_released”?
> Likewise, I have done following command,
> ./rtems-source-builder/sb-set-builder --prefix=/opt/rtems/4.11
> 4.11/rtems-arm --jobs=none
> Result,
> RTEMS Source Builder – Set Builder, 4.11.not-released
> Build Set: 4.11/rtems-arm
> error: no build set file found: 4.11/rtems-arm.bset
> Build Set: Time 0:00:00.011423
> Build FAILED
> Is the cause of “4.11.not_released” same as?
> What is the cause of “no build set file found” and “Build FAILED”?
> users mailing list
> users at rtems.org
