Questions about Configuration for shell prompt & file system
jaeho jo
hot486two at gmail.com
Thu Dec 28 08:34:38 UTC 2017
Hi, I have 2 Questions about RTEMS!
1. What is the relationship between shell prompt and unlimited_object?
When I using RTEMS 4.11.2, I need 'CONFIGURE_UNLIMITED_OBJECTS' to use
shell prompt.
I already read 'RTEMS C User Manual - 24.7. Unlimited Objects ' page,
but I don't understand exactly why I need that configuration.
Also, Can you briefly describe the structural differences associated
with this? between RTEMS 4.10.2 and RTEMS 4.11.2.
2. I wonder if it is designed to ignore file system options when mounting a
file system in RTEMS 4.10.2
I mounted the file system using OSAL source code.
https://github.com/nasa/osal/blob/master/src/os/rtems/osfilesys.c#L529
The 4th parameter of this function determines whether a write
operation is possible to the file system
Option for file system
typedef enum {
RTEMS_FILESYSTEM_READ_ONLY,
RTEMS_FILESYSTEM_READ_WRITE,
RTEMS_FILESYSTEM_BAD_OPTIONS
} rtems_filesystem_options_t; // libio.h
With RTEMS 4.10.2, Even if RTEMS_FILESYSTEM_READ_ONLY(0) is used as an
option of the file system, the file writing to the file system is working
With RTEMS 4.11.2, if RTEMS_FILESYSTEM_READ_ONLY(0) is used as an
option of the file system, the file writing to the file system is not
working.
if RTEMS_FILESYSTEM_READ_WRITE(1) is
used as an option of the file system, the file writing to the file system
is working.
As far as I can see, RTEMS 4.11.2 seems to be working properly.
a file system in RTEMS 4.10.2 or is it a bug?
Thank you for reading the long questions.
jhjo
URL: <http://lists.rtems.org/pipermail/users/attachments/20171228/aa752903/attachment.html>
