rtems from TMS570 SDRAM or INTRAM
AHMED, Asif
asif.a.ahmed at airbus.com
Tue Feb 14 08:19:07 UTC 2017
Hello Mr. Sebastian Huber and everyone,
Thank you for your help. I could make the rtems application (rtems-app.exe)
for big endian tms570. Now that I have got the steps right, I would like to make
simple rtems application for the board I have, which is TMS570lc4357 HDK which
contains arm cortex-r5 processor. That's why I wanted to get the basic
tms570ls3137 application right. I have read that It is possible to use
TMS570ls3137_hdk_sdram or TMS570ls3137_hdk_intram configuration while the
when board is setup by https://github.com/hornmich/tms570ls3137-hdk-sdram
initialization code in the Flash. I would like to start from there so that
I can initialize my TMS570lc4357 HDK board using TI's HALCoGen. I have
checked that lc4357 and ls3137 both the boards use same ISSI 442S16400F
SDRAM CHIP. It would be a great help if you could guide me to steps to
follow. I have created one sdram_sci_configuration ccs project for my
lc4357 board similar to that link and changed the linker cmd file of bsp. I can do the bsp clock and other simple changes. But I am not sure how to integrate rtems
application or what to do next? What should be my next step to keep the initialization in the flash and run rtems application from intram or sdram?
I appreciate your support and help. Thank you.
Best Regards
Asif Ahmed
This email (including any attachments) may contain confidential and/or
privileged information or information otherwise protected from disclosure.
If you are not the intended recipient, please notify the sender immediately,
do not copy this message or any attachments and do not use it for any
purpose or disclose its content to any person, but delete this message and
any attachments from your system.
Astrium and Airbus Group companies disclaim any and all liability if this email transmission
was virus corrupted, altered or falsified.
Airbus DS GmbH
Vorsitzender des Aufsichtsrates: Bernhard Gerwert
Geschäftsführung: Evert Dudok (Vorsitzender), Dr. Lars Immisch, Dr. Michael Menking, Dr. Johannes von Thadden
Sitz der Gesellschaft: München - Registergericht: Amtsgericht München, HRB Nr. 107 647
Ust. Ident. Nr. /VAT reg. no. DE167015356
URL: <http://lists.rtems.org/pipermail/users/attachments/20170214/24954406/attachment.html>
