checking for struct _Thread_queue_Queue._name... no
Hill, Jeff johill at lanl.gov
Thu Feb 23 20:10:17 UTC 2017
Hello All,
I am merging with 4.11.1, but see some gnu autotools configuration errors for nios2-rtems4.11 I haven't seen before. See below. This was probably not occurring when I was merging with nios2-rtems4.11.0 but I haven't yet worked out what the issue is, or if I am causing it locally.
I will be digging deeper into this later today, but if anyone has some suggestions about a cause, then I might avoid some effort.
My toolchain _is_ recently built by RSB for 4.11.1.
Jeff
configure: running /bin/bash '/home/hill/nios2-rtems/rtems/rtems-4-11-merge/c/src/../../cpukit/configure'  '--prefix=/home/hill/install/rtems-4.11' '--host=nios2-rtems4.11' '--build=x86_64-pc-linux-gnu' '--target=nios2-rtems4.11' '--disable-itron' '--disable-tests' '--enable-posix' '--enable-cxx' '--enable-networking' '--enable-maintainer-mode' '--with-target-subdir=nios2-rtems4.11' '--exec-prefix=/home/hill/install/rtems-4.11/nios2-rtems4.11' '--includedir=/home/hill/install/rtems-4.11/nios2-rtems4.11/include' 'build_alias=x86_64-pc-linux-gnu' 'host_alias=nios2-rtems4.11' 'target_alias=nios2-rtems4.11' '--with-project-root=../../' '--with-project-top=../../' 'RTEMS_BSP=altera-sys-config-S43X-BPPM' 'RTEMS_CPU_MODEL=fast' 'RTEMS_BSP_FAMILY=altera-sys-config' 'CFLAGS= -O3 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs' '--with-project-root=../../../altera-sys-config-S43X-BPPM/'    '--includedir=/home/hill/install/rtems-4.11/nios2-rtems4.11/altera-sys-config-S43X-BPPM/lib/include'    '--libdir=/home/hill/install/rtems-4.11/nios2-rtems4.11/altera-sys-config-S43X-BPPM/lib'    --cache-file=/dev/null --srcdir=/home/hill/nios2-rtems/rtems/rtems-4-11-merge/c/src/../../cpukit
checking for gmake... no
checking for make... make
checking build system type... x86_64-pc-linux-gnu
checking host system type... nios2-unknown-rtems4.11
checking rtems target cpu... nios2
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for nios2-rtems4.11-strip... nios2-rtems4.11-strip
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... no
checking for mawk... mawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... yes
/home/hill/nios2-rtems/rtems/rtems-4-11-merge/c/src/../../cpukit/configure: line 3404: RTEMS_ENABLE_CXX: command not found
checking if cpu nios2 is supported... yes
checking for style of include used by make... GNU
checking for nios2-rtems4.11-gcc... nios2-rtems4.11-gcc
checking for nios2-rtems4.11-gcc... (cached) nios2-rtems4.11-gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... yes
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether nios2-rtems4.11-gcc accepts -g... yes
checking for nios2-rtems4.11-gcc option to accept ISO C89... none needed
checking dependency style of nios2-rtems4.11-gcc... gcc3
checking how to run the C preprocessor... nios2-rtems4.11-gcc -E
checking whether nios2-rtems4.11-gcc accepts --pipe... yes
/home/hill/nios2-rtems/rtems/rtems-4-11-merge/c/src/../../cpukit/configure: line 4696: RTEMS_GCC_SPECS: command not found
/home/hill/nios2-rtems/rtems/rtems-4-11-merge/c/src/../../cpukit/configure: line 4720: RTEMS_PROG_CXX_FOR_TARGET: command not found
checking whether nios2-rtems4.11-gcc --pipe and cc understand -c and -o together... yes
checking for nios2-rtems4.11-ar... nios2-rtems4.11-ar
checking for nios2-rtems4.11-ranlib... nios2-rtems4.11-ranlib
checking dependency style of nios2-rtems4.11-gcc --pipe... gcc3
checking for nios2-rtems4.11-ranlib... (cached) nios2-rtems4.11-ranlib
checking for RTEMS newlib... yes
checking for strsep... yes
checking for strcasecmp... yes
checking for snprintf... yes
checking for strdup... yes
checking for strndup... yes
checking for strncasecmp... yes
checking for bcopy... yes
checking for bcmp... yes
checking for isascii... yes
checking for fileno... yes
checking for readdir_r... yes
checking for isatty... yes
checking for creat... yes
checking for opendir... yes
checking for closedir... yes
checking for readdir... yes
checking for rewinddir... yes
checking for scandir... yes
checking for seekdir... yes
checking for sleep... yes
checking for telldir... yes
checking for usleep... yes
checking for __assert... yes
checking for execl... yes
checking for execlp... yes
checking for execle... yes
checking for execv... yes
checking for execvp... yes
checking for execve... yes
checking for regcomp... yes
checking for regexec... yes
checking for regerror... yes
checking for regfree... yes
checking whether flockfile is declared... yes
checking for flockfile... no
checking whether funlockfile is declared... yes
checking for funlockfile... no
checking whether ftrylockfile is declared... yes
checking for ftrylockfile... no
configure: error: please update your tool chain via the RSB <https://docs.rtems.org/branches/master/rsb/quick-start.html>
configure: error: /bin/bash '/home/hill/nios2-rtems/rtems/rtems-4-11-merge/c/src/../../cpukit/configure' failed for ../../cpukit
make[2]: *** [altera-sys-config-S43X-BPPM] Error 1
make[2]: Leaving directory `/home/hill/build/b-rtems/nios2-rtems4.11/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/hill/build/b-rtems/nios2-rtems4.11/c'
make: *** [all-recursive] Error 1
