checking for struct _Thread_queue_Queue._name... no
Joel Sherrill
joel at rtems.org
Thu Feb 23 21:11:48 UTC 2017
On Thu, Feb 23, 2017 at 2:10 PM, Hill, Jeff <johill at lanl.gov> wrote:
> Hello All,
> I am merging with 4.11.1, but see some gnu autotools configuration errors
> for nios2-rtems4.11 I haven't seen before. See below. This was probably not
> occurring when I was merging with nios2-rtems4.11.0 but I haven't yet
> worked out what the issue is, or if I am causing it locally.
> I will be digging deeper into this later today, but if anyone has some
> suggestions about a cause, then I might avoid some effort.
> My toolchain _is_ recently built by RSB for 4.11.1.
Hmmm... if it worked for 4.11.0 and doesn't for 4.11.1 that seems odd since
I
recall there was only a packaging or version number issue fixed between the
two.
This is in <sys/lock.h> for _Thread_queue_Queue structure but on 4.12
not 4.11.
struct _Thread_queue_Queue {
struct _Ticket_lock_Control _Lock;
struct _Thread_queue_Heads *_heads;
struct _Thread_Control *_owner;
const char *_name;
Are you building RTEMS from git and on the master branch not the 4.11
branch?
Or are you using the 4.11.1 tarball?
I can see a git branch issue causing this and it being easy to do. All the
other
things that could have gone wrong seem unlikely.
--joel
> Jeff
> configure: running /bin/bash '/home/hill/nios2-rtems/rtems/
> rtems-4-11-merge/c/src/../../cpukit/configure'
> '--prefix=/home/hill/install/rtems-4.11' '--host=nios2-rtems4.11'
> '--build=x86_64-pc-linux-gnu' '--target=nios2-rtems4.11' '--disable-itron'
> '--disable-tests' '--enable-posix' '--enable-cxx' '--enable-networking'
> '--enable-maintainer-mode' '--with-target-subdir=nios2-rtems4.11'
> '--exec-prefix=/home/hill/install/rtems-4.11/nios2-rtems4.11'
> '--includedir=/home/hill/install/rtems-4.11/nios2-rtems4.11/include'
> 'build_alias=x86_64-pc-linux-gnu' 'host_alias=nios2-rtems4.11'
> 'target_alias=nios2-rtems4.11' '--with-project-root=../../'
> '--with-project-top=../../' 'RTEMS_BSP=altera-sys-config-S43X-BPPM'
> 'RTEMS_CPU_MODEL=fast' 'RTEMS_BSP_FAMILY=altera-sys-config' 'CFLAGS= -O3
> -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration
> -Wstrict-prototypes -Wnested-externs' '--with-project-root=../../../altera-sys-config-S43X-BPPM/'
> s4.11/altera-sys-config-S43X-BPPM/lib/include'
> '--libdir=/home/hill/install/rtems-4.11/nios2-rtems4.11/
> altera-sys-config-S43X-BPPM/lib' --cache-file=/dev/null
> --srcdir=/home/hill/nios2-rtems/rtems/rtems-4-11-merge/c/src/../../cpukit
> checking for gmake... no
> checking for make... make
> checking build system type... x86_64-pc-linux-gnu
> checking host system type... nios2-unknown-rtems4.11
> checking rtems target cpu... nios2
> checking for a BSD-compatible install... /usr/bin/install -c
> checking whether build environment is sane... yes
> checking for nios2-rtems4.11-strip... nios2-rtems4.11-strip
> checking for a thread-safe mkdir -p... /bin/mkdir -p
> checking for gawk... no
> checking for mawk... mawk
> checking whether make sets $(MAKE)... yes
> checking whether to enable maintainer-specific portions of Makefiles... yes
> /home/hill/nios2-rtems/rtems/rtems-4-11-merge/c/src/../../cpukit/configure:
> line 3404: RTEMS_ENABLE_CXX: command not found
> checking if cpu nios2 is supported... yes
> checking for style of include used by make... GNU
> checking for nios2-rtems4.11-gcc... nios2-rtems4.11-gcc
> checking for nios2-rtems4.11-gcc... (cached) nios2-rtems4.11-gcc
> checking whether the C compiler works... yes
> checking for C compiler default output file name... a.out
> checking for suffix of executables...
> checking whether we are cross compiling... yes
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether nios2-rtems4.11-gcc accepts -g... yes
> checking for nios2-rtems4.11-gcc option to accept ISO C89... none needed
> checking dependency style of nios2-rtems4.11-gcc... gcc3
> checking how to run the C preprocessor... nios2-rtems4.11-gcc -E
> checking whether nios2-rtems4.11-gcc accepts --pipe... yes
> line 4696: RTEMS_GCC_SPECS: command not found
> line 4720: RTEMS_PROG_CXX_FOR_TARGET: command not found
> checking whether nios2-rtems4.11-gcc --pipe and cc understand -c and -o
> together... yes
> checking for nios2-rtems4.11-ar... nios2-rtems4.11-ar
> checking for nios2-rtems4.11-ranlib... nios2-rtems4.11-ranlib
> checking dependency style of nios2-rtems4.11-gcc --pipe... gcc3
> checking for nios2-rtems4.11-ranlib... (cached) nios2-rtems4.11-ranlib
> checking for RTEMS newlib... yes
> checking for strsep... yes
> checking for strcasecmp... yes
> checking for snprintf... yes
> checking for strdup... yes
> checking for strndup... yes
> checking for strncasecmp... yes
> checking for bcopy... yes
> checking for bcmp... yes
> checking for isascii... yes
> checking for fileno... yes
> checking for readdir_r... yes
> checking for isatty... yes
> checking for creat... yes
> checking for opendir... yes
> checking for closedir... yes
> checking for readdir... yes
> checking for rewinddir... yes
> checking for scandir... yes
> checking for seekdir... yes
> checking for sleep... yes
> checking for telldir... yes
> checking for usleep... yes
> checking for __assert... yes
> checking for execl... yes
> checking for execlp... yes
> checking for execle... yes
> checking for execv... yes
> checking for execvp... yes
> checking for execve... yes
> checking for regcomp... yes
> checking for regexec... yes
> checking for regerror... yes
> checking for regfree... yes
> checking whether flockfile is declared... yes
> checking for flockfile... no
> checking whether funlockfile is declared... yes
> checking for funlockfile... no
> checking whether ftrylockfile is declared... yes
> checking for ftrylockfile... no
> configure: error: please update your tool chain via the RSB <
> https://docs.rtems.org/branches/master/rsb/quick-start.html>
> configure: error: /bin/bash '/home/hill/nios2-rtems/rtems/
> rtems-4-11-merge/c/src/../../cpukit/configure' failed for ../../cpukit
> make[2]: *** [altera-sys-config-S43X-BPPM] Error 1
> make[2]: Leaving directory `/home/hill/build/b-rtems/nios2-rtems4.11/c'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/hill/build/b-rtems/nios2-rtems4.11/c'
> make: *** [all-recursive] Error 1
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170223/3bcb58ee/attachment-0001.html>
