question about building framework
Fri Jan 6 00:09:39 UTC 2017
On 05/01/2017 10:09, Denis Obrezkov wrote:
> Hello,
Welcome.
> I am trying to understand a building framework architecture.
Ok.
> And I have a lot of questions:
No problem, I have created a long and detailed answer, maybe too long. :)
> what is the future of autotools and waf framework regarding rtems kernel
> and tools?
The autotools build frame work in the RTEMS kernel source is being
patched and no major changes or work is being done on it. We will be
moving to a waf based build system when the time and funds become available.
To the whole community, we would welcome any funding, big or small to
help this effort. It is unrealistic to think it can be done unfunded by
core developers. Please directly contact Joel or me if you can help.
The current waf build tree has 2 parts, the addition of waf and moving
headers away from the pre-install mess we have to single include tree in
the source. Both parts are important and needed. I am currently
evaluating separating these into 2 stages, adding waf first then a
header file move. I feel we can do each stage but together the effort is
too big without a lot of work.
The tools are separate and not related. The build systems the tools use
are contained in those packages and do not effect RTEMS or any RTEMS
application build systems.
> what is the motivation to use wav framework?
I can list the reasons I can think of however build framework
discussions often descend into arguments based on personal preferences
and I would like to avoid that.
Waf is being used because:
- It is built on the proven popular and widely available programming
language, Python. It is not based around a language specially created as
a collection features each designed to solve a specific build problem
that may not scale or interact cleanly with each other. With a proper
programming language at it's base waf lets the build system have an
architecture and designed based on proven software design methodologies
like any other part of the code in the system. You could even have unit
tests for the build system. I often think it is funny how we spend a lot
of time reviewing and auditing code and a build system is often never
reviewed yet it creates the binary that runs on the target and a wrong
flag or option can cause subtle hard to find issues.
- It is fast on all hosts including Windows. It evaluates all targets
before starting a build and automatically runs all cores on multicore hosts.
- It is self contained, no need to have an external package installed to
work. Waf is included as source in the source tree of the package being
built.
> will it replace RSB?
No, the RSB is a separate tool and not unrelated to build systems.
> will it be possible to use makefiles?
I assume you are talking about building applications, yes you can use
Makefiles to build applications.
There is no relationship between a user's build system for an
application and what is used to build the RTEMS kernel. The RTEMS
Project encourages user to select a build system that suites their
project, system or company needs.
Historically RTEMS has documented applications be built with
Makefile.inc which implied a relationship. The unfortunate side effect
of this is the impression there is a direct relationship. The installing
of some of the RTEMS build support files to aid building a specific
niche of applications has created this misunderstanding.
> what is the preferable way of building custom application? makefile or
> wscript?
As stated before there is no preferred method because everyone is
different. People have personal favourites, localised system demands,
integration to larger systems and many more reasons.
The critical factor in an application build system is making sure you
use the same or compatible compiler and linker flags when building your
application for all the code linked into your application. RTEMS is a
statically linked executable so all code needs to conform to the same
ABI and that ABI needs to be supported by your target hardware. The BSP
defines this.
How you handle the compile flags, linker flags and libraries depends on
your system requirements and there is no right or wrong way so when
reviewing comments I suggest you look at posts and comments from other
users as their experiences rather than rules and pick out what works for
you. For example you may hard code the compiler, cflags, ldflags and
libs into your build system because you have a single BSP you need to
support. A more complex case is a single application that needs to run
on a number of different BSPs so you may hard code a number of flags or
extract the information from RTEMS somehow.
RTEMS application build systems can be view as having 3 basic parts:
1. An application build system. This is how code is built and is no
different to any application or package on any OS.
2. Cross-compiling. Do not under estimate what this means.
3. BSP compiler flags, linker flags and libraries.
All build system systems will handle each of these in different ways and
with varying degrees of success. I will avoid going into the strengths
and weaknesses of each system because that is off topic here and I do
not want to get flamed. :)
The important item is 3, BSP compiler and linker flags. There is a
missed place view that all RTEMS applications need to be based on
Makefiles because you need to include Makefile.inc to get the compiler
and linker flags (disclamer: my dislike of Makefile.inc is well known
and over 15 years old).  Let me explain the issue in detail.
Installing and exporting of various pieces of the RTEMS build system to
aid building applications helps a specific niche of users however it has
created a maintenance issue the project can no longer sustain. RTEMS
currently exports to users a makefile fragment from deep within the BSP
with no rules or user interface that is only accessible by the make
program. It is very difficult, almost impossible to parse without
running make due to macros and make variables which means non-make build
systems are excluded. On top of this BSP developers have used a wide and
varying set of make features, eg check the i386/pc686's code base
address of 0x0010000. It is very difficult for the RTEMS Project to
control this.
As a result a future version of RTEMS will *not* export any application
makefile support, ie Makefile.inc, so I recommend users start to
consider this now.
The question remains, how does a user get the compiler and linker flags
for a BSP? We are adding a tools called 'rtems-config' which is simlar
to pkgconfig. You ask it a question about your BSP, eg cflags, ldflags,
libs, and it returns the answer. The tool will be formally supported and
its user interface will be separated from how it works and what happens
inside the RTEMS kernel and source code.
Finally the rtems_waf.git repo in my personal git area provides an easy
to use way to integrate waf and RTEMS for applications. The examples-v2
and libbsd use it.
The rtems_waf.git package uses pkgconfig and some local tweaks to get
the data from installed BSP .pc files. This works but only to a limited
extent. The BSP makefile fragments are too varied to make generating
correct .pc files possible from within RTEMS when building it and the
effort was abandoned and has not and will not progress any further.
