RTEMS Quick Start Instructions Not Working
DiGiorgio, Joseph jdigiorg at ball.com
Thu Jan 19 16:09:44 UTC 2017
Hi,
I have tried several different configurations in following the Quick Start instructions (https://devel.rtems.org/wiki/TBR/UserManual/Quick_Start) and have not had any success getting a successful RTEMS environment up and running. My ultimate goal is to get a powerpc RTEMS running under QEMU, but I have simplified my attempt to purely following the Quick Start guide with SPARC as the target which I can't seem to get that to work.
I have successfully used the "RTEMS Source Builder" to create my cross compiler suite for SPARC architecture (https://docs.rtems.org/rsb/).
I have setup the following directory structure
RTEMS
+---RTEMS_Cross_Tools
|   +---dist
|       +---SPARC
|           +---bin
|           +---include
|           +---lib
|           +---libexec
|           +---share
|           +---sparc-rtems4.12
+---RTEMS_OS
|   +---build
|   +---dist
|   +---Source
and used Git to obtain a recent version of RTEMS:
    cd RTEMS_OS
    git clone git://git.rtems.org/rtems.git ./Source
I am using the following script to build RTEMS:
    export RTEMS_CROSS_TOOLS_PREFIX=/home/xubuntu/Development/RTEMS/RTEMS_Cross_Tools/dist/SPARC
    export RTEMS_INSTALL_PREFIX=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC
    export RTEMS_TARGET_ARCH=sparc-rtems4.12
    export RTEMS_BOARD_SUPPORT_PACKAGE=sis
    PROJECT_DIR=${PWD}
    export PATH=${RTEMS_CROSS_TOOLS_PREFIX}/bin:${PATH}
    if [! -f ../Source/configure]; then
    pushd Source
        echo "Running bootstrap to generate configure files..."
        echo
        ./bootstrap 2>&1 | tee ${PROJECT_DIR}/bootstrap.log
        echo "Bootstrap operation complete..."
        echo
    popd
    read -n 1 -p "Any key to continue, ^c to Terminate..." userinput
    fi
    pushd build
        echo "Configuring RTEMS OS..."
        echo
        ../Source/configure \
            --target=${RTEMS_TARGET_ARCH} \
            --enable-rtemsbsp=${RTEMS_BOARD_SUPPORT_PACKAGE} \
            --prefix=${RTEMS_INSTALL_PREFIX} \
            --enable-tests=samples \
            2>&1 | tee ${PROJECT_DIR}/configure.log
        echo "Configure operation complete."
        echo
    popd
    pushd build
        echo "Building RTEMS OS..."
        echo
        make 2>&1 | tee ${PROJECT_DIR}/build.log
        echo "Build operation complete."
        echo
    popd
    pushd build
        echo "Installing RTEMS OS..."
        echo
        make install 2>&1 | tee ${PROJECT_DIR}/install.log
        echo "Install operation complete."
        echo
    popd
The following is my output for configure and make:
    configure.log
    checking for gmake... no
    checking for make... make
    checking for RTEMS Version... 4.11.99.0
    checking build system type... x86_64-pc-linux-gnu
    checking host system type... x86_64-pc-linux-gnu
    checking target system type... sparc-unknown-rtems4.12
    checking for a BSD-compatible install... /usr/bin/install -c
    checking whether build environment is sane... yes
    checking for a thread-safe mkdir -p... /bin/mkdir -p
    checking for gawk... gawk
    checking whether make sets $(MAKE)... yes
    checking whether to enable maintainer-specific portions of Makefiles... no
    checking that generated files are newer than configure... done
    configure: creating ./config.status
    configure: configuring in ./tools/build
    configure: running /bin/bash '../../../Source/tools/build/configure' '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC' '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu'  '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12'  '--cache-file=/dev/null' '--srcdir=../../../Source/tools/build'
    checking for x86_64-pc-linux-gnu-gcc... no
    checking for gcc... gcc
    checking whether the C compiler works... yes
    checking for C compiler default output file name... a.out
    checking for suffix of executables...
    checking whether we are cross compiling... no
    checking for suffix of object files... o
    checking whether we are using the GNU C compiler... yes
    checking whether gcc accepts -g... yes
    checking for gcc option to accept ISO C89... none needed
    checking for style of include used by make... GNU
    checking dependency style of gcc... gcc3
    checking how to run the C preprocessor... gcc -E
    checking for grep that handles long lines and -e... /bin/grep
    checking for egrep... /bin/grep -E
    checking for ANSI C header files... yes
    checking for sys/types.h... yes
    checking for sys/stat.h... yes
    checking for stdlib.h... yes
    checking for string.h... yes
    checking for memory.h... yes
    checking for strings.h... yes
    checking for inttypes.h... yes
    checking for stdint.h... yes
    checking for unistd.h... yes
    checking getopt.h usability... yes
    checking getopt.h presence... yes
    checking for getopt.h... yes
    checking libgen.h usability... yes
    checking libgen.h presence... yes
    checking for libgen.h... yes
    checking for strerror... yes
    checking for strtol... yes
    checking for basename... yes
    checking for strnlen... yes
    checking for bash... /bin/bash
    config.status: creating Makefile
    config.status: creating install-if-change
    config.status: creating config.h
    config.status: config.h is unchanged
    config.status: executing depfiles commands
    configure: configuring in ./tools/cpu
    configure: running /bin/bash '../../../Source/tools/cpu/configure' '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC' '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu'  '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12'  '--cache-file=/dev/null' '--srcdir=../../../Source/tools/cpu'
    checking rtems target cpu... sparc
    === configuring in generic (/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu/generic)
    configure: running /bin/bash ../../../../Source/tools/cpu/generic/configure --disable-option-checking '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC'  '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu' '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12' 'build_alias=x86_64-pc-linux-gnu' 'host_alias=x86_64-pc-linux-gnu' 'target_alias=sparc-rtems4.12' --cache-file=/dev/null --srcdir=../../../../Source/tools/cpu/generic
    config.status: creating size_rtems
    configure: configuring in ./testsuites/tools
    configure: running /bin/bash '../../../Source/testsuites/tools/configure' '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC' '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu'  '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12'  '--cache-file=/dev/null' '--srcdir=../../../Source/testsuites/tools'
    === configuring in generic (/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools/generic)
    configure: running /bin/bash ../../../../Source/testsuites/tools/generic/configure --disable-option-checking '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC'  '--host=x86_64-pc-linux-gnu' '--build=x86_64-pc-linux-gnu' '--enable-rtemsbsp=sis' '--enable-tests=samples' '--target=sparc-rtems4.12' 'build_alias=x86_64-pc-linux-gnu' 'host_alias=x86_64-pc-linux-gnu' 'target_alias=sparc-rtems4.12' --cache-file=/dev/null --srcdir=../../../../Source/testsuites/tools/generic
    config.status: creating difftest
    config.status: creating sorttimes
    configure: configuring in sparc-rtems4.12/c
    configure: running /bin/bash '../../../Source/c/configure' '--prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC' '--host=sparc-rtems4.12' '--build=x86_64-pc-linux-gnu' '--target=sparc-rtems4.12'  '--enable-rtemsbsp=sis' '--enable-tests=samples' '--with-target-subdir=sparc-rtems4.12' '--exec-prefix=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC/sparc-rtems4.12' '--includedir=/home/xubuntu/Development/RTEMS/RTEMS_OS/dist/SPARC/sparc-rtems4.12/include'  '--cache-file=/dev/null' '--srcdir=../../../Source/c'
    checking host system type... sparc-unknown-rtems4.12
    checking for sparc-rtems4.12-strip... sparc-rtems4.12-strip
    build.log
    Making all in tools/build
    make[1]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/build'
    make  all-am
    make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/build'
    make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/build'
    make[1]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/build'
    Making all in tools/cpu
    make[1]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu'
    Making all in generic
    make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu/generic'
    make[2]: Nothing to be done for 'all'.
    make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu/generic'
    make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu'
    make[2]: Nothing to be done for 'all-am'.
    make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu'
    make[1]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/tools/cpu'
    Making all in testsuites/tools
    make[1]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools'
    make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools/generic'
    make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools/generic'
    make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools'
    make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools'
    make[1]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/testsuites/tools'
    Making all in sparc-rtems4.12/c
    make[1]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/sparc-rtems4.12/c'
    Making all in .
    make[2]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/sparc-rtems4.12/c'
    make[2]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/sparc-rtems4.12/c'
    make[1]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build/sparc-rtems4.12/c'
    make[1]: Entering directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build'
    make[1]: Nothing to be done for 'all-am'.
    make[1]: Leaving directory '/home/xubuntu/Development/RTEMS/RTEMS_OS/build'
When I inspect my build directory, I see make files, but nothing seems to be compiled. I also search for the "samples" test program "ticker" and do not see anything in my project directory. Any ideas what I'm doing wrong?
- Joey D.
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
URL: <http://lists.rtems.org/pipermail/users/attachments/20170119/4fb8b815/attachment-0001.html>
