On 09/01/2017 20:43, Denis Obrezkov wrote: > 2017-01-09 0:09 GMT+02:00 Chris Johns <chrisj at rtems.org > <mailto:chrisj at rtems.org>>: > > On 08/01/2017 19:08, Denis Obrezkov wrote: > > > The same true for LANG="C" readelf -h .... > > > Does the attached patch fix the issue? I will push it if it does. > > Yes, it does. > Pushed. Thank you. Chris
