writing a new bsp question
Joel Sherrill
joel at rtems.org
Mon Jan 23 21:30:41 UTC 2017
On Mon, Jan 23, 2017 at 10:49 AM, Denis Obrezkov <denisobrezkov at gmail.com>
wrote:
> Could you explain how we should create a new bsp.
The first question to ask is "Do I need to write a new BSP?" :)
Second: Can I augment/modify an existing BSP?
I read instructions from the wiki page - great material, but I don't
> understand about building system.
> Should we use RSB? Or first of all write init code, console code and run
> just a bare bsp library .o file?
Whether you use or modify an existing BSP, or create a new one,
you have to have a cross compilation toolset. This is the primary
thing you do with the RSB.
First, use the RSB to build the cross toolset.
Next, I recommend building RTEMS for a BSP from your processor
architecture that runs on a simulator. This gives you something to
easily experiment with and ensure your installation is correct.
What is the HW platform you are looking at?
--joel
> Regards, Denis Obrezkov
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170123/5b4a5fc9/attachment-0002.html>
