stdout and stderr are getting mixed up?
Heinz Junkes
junkes at fhi-berlin.mpg.de
Mon Jul 3 12:48:38 UTC 2017
Can’t confirm running test.c on OS-X
There is never a mix in the output (bufsize == 64):
bbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
> On 03 Jul 2017, at 08:08, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 30/06/17 15:01, Sebastian Huber wrote:
>> Hello,
>> would you mind testing with the latest tool chain (RSB) and the latest RTEMS master:
>> https://git.rtems.org/rtems/commit/?id=9b07f5efe364bc52b80eff83389ee4bf4a1e0c40
>> https://git.rtems.org/rtems-source-builder/commit/?id=5ede1c7e8b1874bbac2f8a3d158bd1c7d802156d
>> I changed Newlib to use global stdio stream FILE objects. With this change a freopen(..., stdin) etc. will close the global stdin FILE object. In order to create thread-local stdio stream objects, you have to use stdin = fopen(...), etc.
> Ok, I should have read the subject more closely. I think its perfectly fine that stdout and stderr streams are mixed up. I did run the attached program on Linux and I get:
> gcc -O2 test.c -pthread && ./a.out 2>&1 | grep ab
> aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaabbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
> aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaabbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
> aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaabbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbbb
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> <test.c>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20170703/4f9d333e/attachment.bin>
