Re: 回复: stdout and stderr are getting mixed up?
Sun Jul 9 22:30:28 UTC 2017
On 08/07/2017 14:35, jameszxj wrote:
> I did some more tests.
> 1. do not initialize network,  everything is OK.
> 2. after initialize network, i use printk to output message, everything is OK.
> 3. after initialize network, i use fprintf(stderr,....)to output message,
> everything is OK.
> 4.after initialize network, i use fprintf(stdout,....)to output message, system
> crash.
> so after libbsd output some messages, something wrong with stdout.
> I am a newbie to RTEMS. Would you give me some advices to dig deeper.
Did you update the tools via the RSB, update the kernel source and bootstrap,
rebuild the BSP and install it, then clean, rebuild and install libbsd?
I am running on a zynq and it is working.
