Building RTEMS for BeagleBone Black failed
Russell Haley russ.haley at gmail.com
Fri Jul 21 02:49:09 UTC 2017
On Wed, Jul 19, 2017 at 11:25 PM, Sebastian Huber
> This looks like a FreeBSD 12 issue. Can you build a native GCC 7.1 on this
> platform? The options.h file is automatically generated. Maybe there is an
> issue with this.
So I finally got an 11.0-RELEASE jail built and followed the quick
start. Interestingly, the rsb is pulling it's host information from
uname so when run in a jail it still configures itself for the host,
not the jail. In this case 12.0-CURRENT. Surprisingly it completed.
<shaking of head>
I'll try building the code with the sparc emulator example from the
website and then loop around to the BB again later.
Russ
