Building RTEMS for BeagleBone Black failed
Russell Haley russ.haley at gmail.com
Fri Jul 21 03:02:32 UTC 2017
On Thu, Jul 20, 2017 at 7:49 PM, Russell Haley <russ.haley at gmail.com> wrote:
> On Wed, Jul 19, 2017 at 11:25 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> This looks like a FreeBSD 12 issue. Can you build a native GCC 7.1 on this
>> platform? The options.h file is automatically generated. Maybe there is an
>> issue with this.
> So I finally got an 11.0-RELEASE jail built and followed the quick
> start. Interestingly, the rsb is pulling it's host information from
> uname so when run in a jail it still configures itself for the host,
> not the jail. In this case 12.0-CURRENT. Surprisingly it completed.
> <shaking of head>
> I'll try building the code with the sparc emulator example from the
> website and then loop around to the BB again later.
> Russ
Sorry, on to the next issue (python this time!):
This happened while trying to bootstrap the source code.
https://pastebin.com/gqx6XG96
