stdout and stderr are getting mixed up?
Thu Jun 22 05:24:58 UTC 2017
On 22/06/17 07:20, Sebastian Huber wrote:
> On 22/06/17 07:14, Chris Johns wrote:
>>> If you need a proper log, then you have to ensure this at
>>> application level.
>> What about this post:
>> https://groups.google.com/d/msg/comp.programming.threads/1-bU71nYgqw/HSfD8625QzkJ
>> It would imply a line should not be broken up. I do not know.
> You have thread-local stdio streams in Newlib that use a common output
> device by default.
For the kernel-space log functions and syslog() in libbsd I added a lock
to serialize the output by default:
https://git.rtems.org/rtems-libbsd/tree/rtemsbsd/rtems/rtems-kernel-vprintf.c?id=9db59c71ad8bc1f1852838d147a29467a1cd6e3d#n81
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
