stdout and stderr are getting mixed up?
Thu Jun 22 05:29:24 UTC 2017
On 22/06/2017 15:20, Sebastian Huber wrote:
> On 22/06/17 07:14, Chris Johns wrote:
>>> If you need a proper log, then you have to ensure this at application level.
>> What about this post:
>> https://groups.google.com/d/msg/comp.programming.threads/1-bU71nYgqw/HSfD8625QzkJ
>> It would imply a line should not be broken up. I do not know.
> You have thread-local stdio streams in Newlib that use a common output device by
> default.
Is what we do acceptable standard behavior?
The link I posted would suggest otherwise. RTEMS 4.9, 4.10, and 4.11 did not do
this so is this a regression?
