How to make a rtems kernel shell prompt to qemu console?
jaeho jo hot486two at gmail.com
Fri Jun 23 07:01:22 UTC 2017
I want to see shell prompt on qemu and run another simple program using
file system.
Done :
           Make install on rtems i386 pc386
First time, I thought I have to make a kernel image to target emulator(qemu)
  - kernel image -> qemu -> shell prompt on qemu
But, I saw this mailing list -
https://lists.rtems.org/pipermail/users/2015-December/029626.html
and found out rtems doesn’t work like that and rtems builds a single
monolithic binary.
I also found out the samples in rtems directory and fileio.exe is similar
to shell prompt.
If I want to use shell prompt on qemu, I have to modify fileio source code
and build fileio.exe, emulate this binary file?
Also, I found out this link - https://github.com/alanc98/rki
without another source download, Is there any other option to build it? I
think Maybe I have to use file system.
URL: <http://lists.rtems.org/pipermail/users/attachments/20170623/eded0978/attachment.html>
