Dynamic load real-time tasks
Joel Sherrill
joel at rtems.org
Mon Jun 26 15:03:56 UTC 2017
On Mon, Jun 26, 2017 at 3:34 AM, Павел Жданов <paul.alex.zhdanov at gmail.com>
wrote:
> Hello everyone.
> I'm interested in dynamic loading and have the following situation:
> 1. There are two files init.c and dl.c.
> 2. dl.с defines rtems_main function . This function just print some
> string using printf fuction. It complied to dl.o but not linked against
> standard libraries so printf symbol is unresolved.
> 3. I want to load dl.o from init.с and use rtems_main function (with
> dl_open and so on). Final init.exe is linked against standard libraries so
> it has printf symbol resolved.
> 4. dl.o is loaded from the dos partition.
> 5. At the moment a can load dl.o and call rtems_main only if it
> doesn't use printf or functions from other libraries.
> My questions are:
> 1. Is this scenario possible?
> 2. How to link dl.o with init.exe to resolve printf (and may be other
> functions that are used by rtems_main and resolved in init.exe)?
> The general "trick" is to figure out which common methods/symbols should
be
in the base image onto which dl.o is loaded. Chris may have other tricks but
I would start with the "--undefined" argument to ld and add symbols.
Otherwise, each dl object will end up with pieces of the C library linked
into it
and you have to manage the dependencies.
> Platfrom: i386, pc486. I tried to use rtems-ld and i386-rtems4.11-ld but
> could not resolve necessary symbols.
Beyond the libdl supporting you architecture, it shouldn't matter but good
to know.
--joel
> Best regards,
> Pavel Zhdanov.
> С уважением, Жданов Павел.
> On Wed, May 3, 2017 at 1:24 PM, Павел Жданов <paul.alex.zhdanov at gmail.com>
> wrote:
>> Hi.
>> Really, is it possible to load tasks dynamically in runtime? I'm
>> interested in software updating. So far I think that final executable file
>> in RTEMS is monolithic image. It's big and it's take a lot of time to
>> upload it via serial port. If it's not modular then I can't upload new task
>> and start it. Can you suggest some methods that can be used to update RTEMS
>> task at runtime? For example update some of its functions using the dynamic
>> linker (dlopen, ...).
>> Best regards,
>> Pavel Zhdanov
>> On Wed, Apr 5, 2017 at 10:22 AM, xuelin.tian at qkmtech.com <
>> xuelin.tian at qkmtech.com> wrote:
>>> Dear all,
>>> Can I load real-time tasks using real-time loader?
>>> In my opinion, loading real-time tasks means that I can append my own
>>> application tasks to the interrupt ISR, and this task can be invoked based
>>> on a predefined frequency.
>>> In VxWorks, I need to disable interrupt first, using sysAuxClkDisable,
>>> and enable this interrupt after install my application tasks.
>>> Do we have the same mechanism in RTEMS?
>>> Best wishes,
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170626/e1199d5a/attachment.html>
