Dynamic load real-time tasks
Tue Jun 27 04:41:56 UTC 2017
On 26/06/2017 18:34, Павел Жданов wrote:
> Hello everyone.
> I'm interested in dynamic loading and have the following situation:
>  1. There are two files init.c and dl.c.
>  2. dl.с defines rtems_main function . This function just print some string
>     using printf fuction. It complied to dl.o but not linked against standard
>     libraries so printf symbol is unresolved.
>  3. I want to load dl.o from init.с and use rtems_main function (with dl_open
>     and so on). Final init.exe is linked against standard libraries so it has
>     printf symbol resolved.
>  4. dl.o is loaded from the dos partition.
>  5. At the moment a can load dl.o and call rtems_main only if it doesn't use
>     printf or functions from other libraries.
> My questions are:
>  1. Is this scenario possible?
Yes.
>  2. How to link dl.o with init.exe to resolve printf (and may be other functions
>     that are used by rtems_main and resolved in init.exe)?
Have you loaded a symbol table for the base image that contains the 'printf'
function. To create see:
https://docs.rtems.org/branches/master/user/tools/index.html#rtems-symbols
> Platfrom: i386, pc486. I tried to use rtems-ld and i386-rtems4.11-ld but could
> not resolve necessary symbols.
Dynamic loading of code requires the dependence between your base image code,
dynamically loaded and the system libraries needs to be managed. You can do this
manually and Joel gave a hint, or could take a look at the RAP format executable
format the 'rtems-ld' generates.
