MVME 2307 BSP Exceptions
Matt Rippa
mrippa at gemini.edu
Tue Jun 27 03:40:49 UTC 2017
Hi Till, all:
Last week we recommissioned one of our telescope systems using RTEMS and
EPICS on the MVME2307 BSP. After nearly two days of uptime (~42 hours), we
get various unrecoverable exceptions (shown below). This occurs suddenly
when the system is "idle" and not being used for many hours.
Any suggestions tracking down this stack trace, finding the offending
application code, or getting this to fail-faster?
We've produced an object dump available at the following link:
https://github.com/rcardenes/crcs-info
Has anyone else used the MVME2307 BSP?
Thanks,
-Matt
System details:
RTEMS: 4.10.2
EPICS: 3.14.12.4.
Hardware: MVME-2700 (using mvme2307 alias)
VME Boards:
1. Bancomm 635 Time Board
2. PMAC 1
3. Xycom-240
*Event #1:*
> Jun 23 15:19:43 E) PORT: crcs, MSG: Exception handler called for
> exception 7 (0x7)
> Jun 23 15:19:43 E) PORT: crcs, MSG: #011 Next PC or Address of fault =
> 011B010C
> Jun 23 15:19:43 E) PORT: crcs, MSG: #011 Saved MSR = 0008B032
> Jun 23 15:19:43 E) PORT: crcs, MSG: #011 Context: Task ID 0x0A01004B
> Jun 23 15:19:43 E) PORT: crcs, MSG: #011 R0 = 01010101 R1 = 00AF5A40 R2
> = 00000000 R3 = 007F8014
> Jun 23 15:19:43 E) PORT: crcs, MSG: #011 R4 = 00000014 R5 = 007AD148 R6
> = 00AF62BC R7 = 00000000
> Jun 23 15:19:43 E) PORT: crcs, MSG: #011 R8 = 000031A8 R9 = 011B0101
> R10 = 00AF62B8 R11 = 007AD148
> Jun 23 15:19:44 E) PORT: crcs, MSG: #011 R12 = 22000022 R13 = 001E4B90
> R14 = AEFE7BBF R15 = 77FF7FBB
> Jun 23 15:19:44 E) PORT: crcs, MSG: #011 R16 = AA7FBFFC R17 = FF7FF5FF
> R18 = 001E0000 R19 = 00000000
> Jun 23 15:19:44 E) PORT: crcs, MSG: #011 R20 = 000634A0 R21 = 001929E8
> R22 = 001A2284 R23 = 00191098
> Jun 23 15:19:44 E) PORT: crcs, MSG: #011 R24 = 00000000 R25 = 00000001
> R26 = 00000001 R27 = 001A85C4
> Jun 23 15:19:44 E) PORT: crcs, MSG: #011 R28 = 00AF62BC R29 = 00000028
> R30 = 00419260 R31 = 007AD148
> Jun 23 15:19:44 E) PORT: crcs, MSG: #011 CR = 22042028
> Jun 23 15:19:44 E) PORT: crcs, MSG: #011 CTR = 011B00FF
> Jun 23 15:19:44 E) PORT: crcs, MSG: #011 XER = 20000000
> Jun 23 15:19:44 E) PORT: crcs, MSG: #011 LR = 0006371C
> Jun 23 15:19:44 E) PORT: crcs, MSG: #011 DAR = 00000000
> Jun 23 15:19:44 E) PORT: crcs, MSG: Stack Trace:
> Jun 23 15:19:44 E) PORT: crcs, MSG: IP: 0x011B010C, LR: 0x0006371C
> Jun 23 15:19:44 E) PORT: crcs, MSG: --^ 0x0006371C--^ 0x00082FDC--^
> 0x000E7094--^ 0x00136048--^ 0x00135F6C
> Jun 23 15:19:44 E) PORT: crcs, MSG: Suspending faulting task (0x0A01004B)
Using the memory map for the Exception 7 we reach the following trace:
0x00135f6c _Thread_Handler
/gem_sw/targetOS/RTEMS/source/rtems/rtems-4.10.2/cpukit/score/src/threadhandler.c:80
0x00136048
/gem_sw/targetOS/RTEMS/source/rtems/rtems-4.10.2/cpukit/score/src/threadhandler.c:145
0x000e7094
/gem_sw/epics/R3.14.12.4/base/src/libCom/osi/os/RTEMS/osdThread.c:169
0x00082fdc
/gem_sw/epics/R3.14.12.4/base/src/db/dbEvent.c:883
0x0006371c
/gem_sw/targetOS/RTEMS/source/tools/gcc-4.4.7/newlib/libc/stdio/vfscanf.c:270
Power Cycle
*Event #2:*
> Jun 23 18:32:20 E) PORT: crcs, MSG: Exception handler called for
> exception 3 (0x3)
> Jun 23 18:32:20 E) PORT: crcs, MSG: #011 Next PC or Address of fault =
> 001541E4
> Jun 23 18:32:20 E) PORT: crcs, MSG: #011 Saved MSR = 00009032
> Jun 23 18:32:20 E) PORT: crcs, MSG: #011 Context: Task ID 0x09010001
> Jun 23 18:32:20 E) PORT: crcs, MSG: #011 R0 = FFF5A4DA R1 = 00366720 R2
> = 00000000 R3 = FFF0A442
> Jun 23 18:32:20 E) PORT: crcs, MSG: #011 R4 = 00352498 R5 = 00000008 R6
> = 00000000 R7 = FFF0A442
> Jun 23 18:32:20 E) PORT: crcs, MSG: #011 R8 = 00352498 R9 = 00000002
> R10 = 00000000 R11 = 00000001
> Jun 23 18:32:20 E) PORT: crcs, MSG: #011 R12 = 003BC0E0 R13 = 001E4B90
> R14 = 00000000 R15 = 00000000
> Jun 23 18:32:21 E) PORT: crcs, MSG: #011 R16 = 00000000 R17 = 00000000
> R18 = 00000000 R19 = 00000000
> Jun 23 18:32:21 E) PORT: crcs, MSG: #011 R20 = 00000000 R21 = 00000000
> R22 = 00000000 R23 = 00000000
> Jun 23 18:32:21 E) PORT: crcs, MSG: #011 R24 = 00000000 R25 = 00000000
> R26 = 00000000 R27 = 00000000
> Jun 23 18:32:21 E) PORT: crcs, MSG: #011 R28 = FFF0A340 R29 = 00000000
> R30 = FFF0A341 R31 = 0034D5B0
> Jun 23 18:32:21 E) PORT: crcs, MSG: #011 CR = 40000004
> Jun 23 18:32:21 E) PORT: crcs, MSG: #011 CTR = 0012E3AC
> Jun 23 18:32:21 E) PORT: crcs, MSG: #011 XER = 00000000
> Jun 23 18:32:21 E) PORT: crcs, MSG: #011 LR = 000F2CDC
> Jun 23 18:32:21 E) PORT: crcs, MSG: #011 DAR = FFF0A442
> Jun 23 18:32:21 E) PORT: crcs, MSG: Stack Trace:
> Jun 23 18:32:21 E) PORT: crcs, MSG: IP: 0x001541E4, LR: 0x000F2CDC
> Jun 23 18:32:21 E) PORT: crcs, MSG: --^ 0x00135F6C
> Jun 23 18:32:21 E) PORT: crcs, MSG: Suspending faulting task (0x09010001)
*Event #3:*
> Jun 24 07:37:50 E) PORT: crcs, MSG: *Exception handler called for exception
> 8 (0x8)
> Jun 24 07:37:50 E) PORT: crcs, MSG: #011 Next PC or Address of fault =
> 0015BB08
> Jun 24 07:37:50 E) PORT: crcs, MSG: #011 Saved MSR = 00009032
> Jun 24 07:37:50 E) PORT: crcs, MSG: #011 Context: Task ID 0x09010001
> Jun 24 07:37:50 E) PORT: crcs, MSG: #011 R0 = 00157754 R1 = 003664B8 R2
> = 00000000 R3 = 00366758
> Jun 24 07:37:50 E) PORT: crcs, MSG: #011 R4 = 0036661C R5 = 001B4C68 R6
> = 00366610 R7 = 00000000
> Jun 24 07:37:50 E) PORT: crcs, MSG: #011 R8 = 005F5370 R9 = 00642450
> R10 = 0034C940 R11 = 00366688
> Jun 24 07:37:50 E) PORT: crcs, MSG: #011 R12 = 40000048 R13 = 001E4B90
> R14 = 001B4C68 R15 = 00000000
> Jun 24 07:37:51 E) PORT: crcs, MSG: #011 R16 = 00000000 R17 = 00000000
> R18 = 00000000 R19 = 00366610
> Jun 24 07:37:51 E) PORT: crcs, MSG: #011 R20 = 00000000 R21 = 00000000
> R22 = 00366758 R23 = 001B4CC0
> Jun 24 07:37:51 E) PORT: crcs, MSG: #011 R24 = 0036661C R25 = 00377E40
> R26 = 00000000 R27 = 0000002F
> Jun 24 07:37:51 E) PORT: crcs, MSG: #011 R28 = 00377E40 R29 = 001E49B0
> R30 = 00377E40 R31 = 00000000
> Jun 24 07:37:51 E) PORT: crcs, MSG: #011 CR = 40000048
> Jun 24 07:37:51 E) PORT: crcs, MSG: #011 CTR = 00000000
> Jun 24 07:37:51 E) PORT: crcs, MSG: #011 XER = 00000000
> Jun 24 07:37:51 E) PORT: crcs, MSG: #011 LR = 00157754
> Jun 24 07:37:51 E) PORT: crcs, MSG: #011 DAR = 00000000
> Jun 24 07:37:51 E) PORT: crcs, MSG: Stack Trace:
> Jun 24 07:37:51 E) PORT: crcs, MSG: IP: 0x0015BB08, LR: 0x00157754
> Jun 24 07:37:51 E) PORT: crcs, MSG: --^ 0x00157754--^ 0x000F2820--^
> 0x000F2DA0--^ 0x001E49BD--^ 0x00135F6C
> Jun 24 07:37:51 E) PORT: crcs, MSG: Suspending faulting task (0x09010001)
URL: <http://lists.rtems.org/pipermail/users/attachments/20170626/dd67e31b/attachment-0001.html>
