memory issues
yaron o jaron0123 at gmail.com
Tue Jun 27 13:51:17 UTC 2017
Hello everyone.
i have a BUS with small ram memory (2MB).
my code having a lot of global variables and static variables and many many
code lines.
i get this error when execute : "bootcard : work space too big for work
area: # > # "
what should i reduce in order to make enough work space? .
also  there is a limited space  for the code segment ? or the data segment?
i don't know maybe rtems restrict block of memory to data segment that i
cant exceed it.. or i can change it...
one more question , there is a way to calculate how much memory my program
holds in the ram , including the rtems os ,when the program load it say how
much capacity but it not very accurate..
the BUS using leon 3 processor, and i using grmon as a debugger
thanks for helpers!
Yaron .
[image: signature-1.gif]
URL: <http://lists.rtems.org/pipermail/users/attachments/20170627/f49f7fed/attachment.html>
