Conversion to new test suite_GSOC
Mon Mar 20 12:03:18 UTC 2017
On 20/03/17 12:56, Cillian O'Donnell wrote:
> Just to be clear and sorry to belabour a point that must seem very
> obvious to you Amar. Has the framework been established but has not
> yet been implemented in the testsuite, so the style of the new
> testsuite will follow the unity style testing but none of the code in
> the testsuite actually uses this format yet. So this is the beginning
> of the next phase of the project where each test will be gone through
> one by one and converted to the new format.
The unity testing framework is by no means good enough for the RTEMS
testsuite. It lacks some important features like thread-safety at a
basic level.
Before someone starts to work on a test suite conversion several things
must be discussed first.
What are the requirements for the testing framework?
What is the specification input for the tests itself?
How is the output produced at the device level?
How is the output produced for test suite status consumers?
And so on.
It is a several man month project if you want to do this right.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
