A problem of rtems build
Tanu Hari Dixit tokencolour at gmail.com
Mon Mar 13 12:30:39 UTC 2017
Hi LiBing,
What exactly was the error?
Did you run configure command after bootstrapping?
You can consider looking at the steps documented here:
https://docs.rtems.org/branches/master/user/start/index.html
Regards,
Tanu Hari Dixit.
On Mon, Mar 13, 2017 at 5:46 PM, libing403 <libing18934721626 at gmail.com>
wrote:
> Hello,
>       I have ran the Rtems Source Builder with "all.bset" that contain
> seventeen architectures. it took about 12 hours and succeed.
>       what I need to do after that? could I begin to build the Rtems . But
> when I build the Rtems ,there are many errors.
> The command line that I used are following:
> (1)Rtems source Build
> $ sudo apt-get build-dep binutils gcc g++ gdb unzip git python2.7-dev
> $ export PATH=$HOME/development/rtems/4.12/bin:$PATH
> $ cd
> $ mkdir -p development/rtems/src
> $ cd development/rtems/src
> $ git clone git://git.rtems.org/rtems-source-builder.git
> $ cd rtems-source-builder
> $ source-builder/sb-check
> RTEMS Source Builder environment is ok
> $ cd rtems
>  $ ../source-builder/sb-set-builder --log=l-all.txt  \
>                 --prefix=$HOME/development/rtems/4.12  4.12/rtems-all
> (2)Rtems build
> $ cd ~/development/rtems/src
> $ git clone git://git.rtems.org/rtems.git
> $ cd rtems
> $ ./bootstrap
> After ran this command line , there are many warning, and ran
> $make
>  Error occurred
>  I would be grateful for any tips.
> Regards,
> LiBing
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170313/700361d2/attachment-0002.html>
