Best way to use RTEMS in existing project
Olivier C. Larocque oclarocque at gmail.com
Fri May 19 09:55:37 UTC 2017
On Fri, May 19, 2017 at 8:03 AM, Sebastian Huber
> Hello,
> On 18/05/17 12:20, Olivier C. Larocque wrote:
>> Hi everyone,
>> I have a project using Eclipse and System Workbench for STM32 (GNU ARM
>> embedded toolchain) targeting a STM32F446 microcontroller. I am using
>> a proprietary RTOS right now and would like to swap it for RTEMS so I
>> can open source my work.
>> I went through RTEMS documentation and did some tests to familiarize
>> myself with RTEMS build system and how it handles BSPs.
>> What I need to know is what is the best way to proceed.
>> Do I need to use the complete RTEMS build system or I can add the core
>> RTEMS OS files into my project and make the Eclipse build system
>> manage them like I was doing with my other RTOS?
> there is an RTEMS plug-in for Eclipse that used to work with an ancient
> version of Eclipse. Unfortunately it doesn't work with newer versions of CDT
> due to API incompatibilities. I was not really satisfied with the
> automatically generated build stuff from Eclipse. It worked well in simple
> scenarios, but not for larger distributed projects.
Thanks for your input on that. I was to give the plug-in a try but now will not.
> I would use waf to build the application. This should work with Eclipse if
> you disable the automatic builder.
Okay, I'll read on waf to see how it works. Do people sometimes use
the RTEMS build system to build their application code? I saw a
tutorial to build RTEMS from Eclipse, but figured out it was for the
OS and BSP development only and not for application code.
Ref: ftp://ftp.rtems.org/pub/rtems/people/chrisj/docs/eclipse/rtems.html
Thanks
Olivier
