Best way to use RTEMS in existing project
Fri May 19 10:02:55 UTC 2017
On 19/05/17 11:55, Olivier C. Larocque wrote:
>> >I would use waf to build the application. This should work with Eclipse if
>> >you disable the automatic builder.
> Okay, I'll read on waf to see how it works. Do people sometimes use
> the RTEMS build system to build their application code? I saw a
> tutorial to build RTEMS from Eclipse, but figured out it was for the
> OS and BSP development only and not for application code.
> Ref:ftp://ftp.rtems.org/pub/rtems/people/chrisj/docs/eclipse/rtems.html
Doing OS and BSP development for RTEMS with Eclipse is a good method to
turn mad.
For applications on top of RTEMS its more or less suitable.
https://devel.rtems.org/wiki/Developer/Eclipse/Plugin
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
