Best way to use RTEMS in existing project
Fri May 19 21:51:47 UTC 2017
On 19/5/17 8:20 pm, Olivier C. Larocque wrote:
> On Fri, May 19, 2017 at 12:02 PM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 19/05/17 11:55, Olivier C. Larocque wrote:
>>>>> I would use waf to build the application. This should work with Eclipse
>>>>> if
>>>>> you disable the automatic builder.
>>> Okay, I'll read on waf to see how it works. Do people sometimes use
>>> the RTEMS build system to build their application code? I saw a
>>> tutorial to build RTEMS from Eclipse, but figured out it was for the
>>> OS and BSP development only and not for application code.
>>> Ref:ftp://ftp.rtems.org/pub/rtems/people/chrisj/docs/eclipse/rtems.html
This link is better:
https://docs.rtems.org/branches/master/eclipse/index.html
>> Doing OS and BSP development for RTEMS with Eclipse is a good method to turn
>> mad.
> I usually use Eclipse as a convenient GDB frontend, but yes, that
> would probably be more for application level code.
Yes this is correct. I was using it as a way to debug the i386 PC BSP on
Windows and it worked well.
The documentation is a start and I have done building the kernel. I
provided it to be complete and to see if it could be done without
plugins which grow old and break.
>> For applications on top of RTEMS its more or less suitable.
>> https://devel.rtems.org/wiki/Developer/Eclipse/Plugin
> Ok I guess this link if for reference only since you seem to be saying
> that the plug-in doesn't work anymore.
I have not looked at applications created with Eclipse. It would be good
to have something documented.
