Best way to use RTEMS in existing project
Olivier C. Larocque oclarocque at gmail.com
Fri May 19 10:20:19 UTC 2017
On Fri, May 19, 2017 at 12:02 PM, Sebastian Huber
> On 19/05/17 11:55, Olivier C. Larocque wrote:
>>> >I would use waf to build the application. This should work with Eclipse
>>> > if
>>> >you disable the automatic builder.
>> Okay, I'll read on waf to see how it works. Do people sometimes use
>> the RTEMS build system to build their application code? I saw a
>> tutorial to build RTEMS from Eclipse, but figured out it was for the
>> OS and BSP development only and not for application code.
>> Ref:ftp://ftp.rtems.org/pub/rtems/people/chrisj/docs/eclipse/rtems.html
> Doing OS and BSP development for RTEMS with Eclipse is a good method to turn
> mad.
I usually use Eclipse as a convenient GDB frontend, but yes, that
would probably be more for application level code.
> For applications on top of RTEMS its more or less suitable.
> https://devel.rtems.org/wiki/Developer/Eclipse/Plugin
Ok I guess this link if for reference only since you seem to be saying
that the plug-in doesn't work anymore.
