ifLib.c missing/not ported to rtems-libbsd???
Phong Pham
phongvanpham at yahoo.com
Mon May 22 17:00:11 UTC 2017
Sebastian,
> The i386 BSP may not work with the latest libbsd version. In addition, the i386 BSP should be replaced with an x86_64 BSP.
Just want a clarification, the code that is checked in to the main line is not guarantee to be compile-able as in this case, compiling a BSP like pc386.cfg in ...\rtems\c\src\lib\libbsp\i386\pc386\make\custom, install them, and compiling rtems-libbsd will result a compilation failure?
In another word, you are not guaranteeing everything on rtems-libbsd main line to be at least compileable? If you're not guaranteeing that, then would it make sense to not even include LIBBSP_I386_PC386_BSP_H support in nexus-devices.h? In my opinion, the best way is to only add a given BSP in nexus-devices.h when it can be shown to be compileable.
Phong.
URL: <http://lists.rtems.org/pipermail/users/attachments/20170522/c29fc168/attachment.html>
