unable to compile rtems-libbsd
Karim, Hassan hassan.karim at bison.howard.edu
Thu May 11 16:46:45 UTC 2017
Make sure that you have all of the dependencies installed first.
But if the build process is not what you need to get experience with, try
using the rtems-vagrant builds. I'll be sending one out soon.
Regards,
Hassan Karim, CISSP
Ph.D. Student
Computer Science
Howard University
+1202-569-1012
On May 11, 2017 12:26 PM, "Pham, Phong" <phamp at ddc-web.com> wrote:
Hi,
After following the README.waf procedure, I receive the following error (at
the end of the email) in step 8 right when I issued waf command.
Any advise on the compiler error below?  I am currently using RTEMS
checkedout (cloned) on May 8th 2017 but the tool chain (RSB) that I
successfully compiled is early Jan.  Re-cloning tool chain w/ today’s
date???
I randomly selected powerpc virtex5 RTEMS BSP, configure it, make, make
install it, re-configure waf, run waf and still receive the same error…  Do
you have a PowerPC BSP that is known to be compatible with rtems-libbsd so
that waf can compile so I can use it as a baseline?  I know the README.waf
provide xilinx_zynq_a9_qemu as a BSP ex. but it is for ARM…
Thanks,
Phong.
Below is the compiler error when I use my scs750 BSP.
In file included from ../../freebsd/sbin/pfctl/parse.y:76:0:
../../freebsd/include/err.h:49:1: error: expected '=', ',', ';', 'asm' or
'__attribute__' before 'void'
void err(int, const char *, ...) __dead2 __printf0like(2, 3);
In file included from ../../freebsd/sbin/pfctl/parse.y:78:0:
/home/phamp/development/rtems/4.12/powerpc-rtems4.12/include/pwd.h:51:1:
error: expected '=', ',', ';', 'asm' or '__attribute__' before 'struct'
struct passwd {
../../freebsd/sbin/pfctl/parse.y: In function '_bsd_pfctl_pfctlyparse':
../../freebsd/sbin/pfctl/parse.y:3342:24: error: 'struct passwd' has no
member named 'pw_uid'
     $$ = pw->pw_uid;
Build failed
-> task in 'yacc_pfctly' failed with exit status 1:
              {task 44351728: c parse.c -> parse.c.10.o}
['/home/phamp/development/rtems/4.12/bin/powerpc-rtems4.12-gcc', '-qrtems',
'-B/home/phamp/development/rtems/4.12/powerpc-rtems4.12/lib/',
'-B/home/phamp/development/rtems/4.12/powerpc-rtems4.12/scs750/lib/',
'--specs', 'bsp_specs', '-mcpu=750', '-mcpu=750', '-mmultiple',
'-mmultiple', '-mstring', '-mstring', '-mstrict-align', '-mstrict-align',
'-O2', '-g', '-fno-strict-aliasing', '-ffreestanding', '-fno-common', '-w',
'-Irtemsbsd/powerpc/include', '-I../../rtemsbsd/powerpc/include',
'-Ifreebsd/sys/powerpc/include', '-I../../freebsd/sys/powerpc/include',
'-Irtemsbsd/include', '-I../../rtemsbsd/include', '-Ifreebsd/sys',
'-I../../freebsd/sys', '-Ifreebsd/sys/contrib/pf',
'-I../../freebsd/sys/contrib/pf', '-Ifreebsd/sys/net',
'-I../../freebsd/sys/net', '-Ifreebsd/include', '-I../../freebsd/include',
'-Ifreebsd/lib', '-I../../freebsd/lib', '-Ifreebsd/lib/libbsdstat',
'-I../../freebsd/lib/libbsdstat', '-Ifreebsd/lib/libc/include',
'-I../../freebsd/lib/libc/include', '-Ifreebsd/lib/libc/isc/include',
'-I../../freebsd/lib/libc/isc/include', '-Ifreebsd/lib/libc/resolv',
'-I../../freebsd/lib/libc/resolv', '-Ifreebsd/lib/libutil',
'-I../../freebsd/lib/libutil', '-Ifreebsd/lib/libkvm',
'-I../../freebsd/lib/libkvm', '-Ifreebsd/lib/libmemstat',
'-I../../freebsd/lib/libmemstat', '-Ifreebsd/lib/libipsec',
'-I../../freebsd/lib/libipsec', '-Ifreebsd/contrib/expat/lib',
'-I../../freebsd/contrib/expat/lib', '-Ifreebsd/contrib/libpcap',
'-I../../freebsd/contrib/libpcap', '-Ifreebsd/contrib/libxo',
'-I../../freebsd/contrib/libxo', '-Irtemsbsd/sys', '-I../../rtemsbsd/sys',
'-ImDNSResponder/mDNSCore', '-I../../mDNSResponder/mDNSCore',
'-ImDNSResponder/mDNSShared', '-I../../mDNSResponder/mDNSShared',
'-ImDNSResponder/mDNSPosix', '-I../../mDNSResponder/mDNSPosix',
'-Itestsuite/include', '-I../../testsuite/include',
'-DHAVE_RTEMS_SCORE_CPUOPTS_H=1', '-DHAVE_RTEMS_H=1',
'../../freebsd/sbin/pfctl/parse.c', '-c', '-o/home/phamp/Desktop/rtems-
dev/rtems_0508/rtems-libbsd/build/powerpc-rtems4.12-
scs750/freebsd/sbin/pfctl/parse.c.10.o']
Notice: This e-mail and any files transmitted with it may contain Data
Device Corporation's privileged and proprietary information. It is intended
solely for the use of the individual or entity to whom it is addressed. If
you are not the named recipient of this transmission, any disclosure,
copying, distribution or reliance on the contents of this message is
prohibited. If you received this e-mail in error, please destroy it and any
attached files and notify me immediately.
users mailing list
users at rtems.org
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20170511/6c77c2cd/attachment-0002.html>
