Debugging RTEMS application for zedboard
Gabriel Brusq
gabriel.brusq at student.isae-supaero.fr
Thu May 18 08:21:53 UTC 2017
>> I've heard GDB does not support dynamic positioning of breakpoint
>> which means that breakpoint must be set before compiling, with function breakpoint()
> This is not the case. The CortexA9 supports break point instructions as
> well as a hardware break and watch points.
Well if I understand I should compile rtems-gdb and I could easily debug source-level ?
>> Is there any other source-level debugging option ?
> There are a number of options depending on your projects needs and
> budget. I suggest you review the Zynq - Zedboard wiki page:
> https://devel.rtems.org/wiki/Boards/Zynq%20-%20Zedboard
> I use JTAG with OpenOCD and libdebugger. The libdebugger support is
> usable but has some issues I am looking into.
What are the benefits to use OpenOCD instead of GDB ?
Regarding libdebugger I found your previous thread https://lists.rtems.org/pipermail/devel/2016-November/016430.html
What is this library for ? How is it used ?
Thanks for your answers,
Gabriel Brusq
URL: <http://lists.rtems.org/pipermail/users/attachments/20170518/6e777da4/attachment-0002.html>
