Building RSB (RTEMS Source Builder) on Windows 10
Jacob Saina
jsaina at terpmail.umd.edu
Tue Nov 14 01:46:20 UTC 2017
Hello,
I'm attempting to build RSB 4.11.2, which I obtained from here:
https://ftp.rtems.org/pub/rtems/releases/4.11/4.11.2/
using the guide here:
https://ftp.rtems.org/pub/rtems/people/chrisj/doc-online/master/user/index.html
on a Windows 10 machine, for ARM targets.
I am using MSYS2 with the specified packages installed. My build fails on
ark41. The error report is attached.
1) Any insight on this ark41 failure is appreciated.
2) I've noticed that the "rsb-report-arm-rtems4.11-kernel...." file
(attached) says "RSB: not a valid repo." What does this mean?
3) My build seems to take an excessively long time given my hardware -- it
fails in ~5.5 hours with a brand new laptop with i7, 16GB RAM, and SSDs. My
coworker had no problems on an older laptop with v4.11.0, and that
completed in 3:40.
4) I've noticed that virus detection software to really spins up during an
RSB build, so I've disabled it. (Note that the 5.5 hour figure is with
virus detection disabled.) Have others noticed this? Will it cause problems?
Thanks for your help,
Jacob
Tail of the log (also included in the error report, but this has the build
time):
___________________________________________________________
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/
-B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems
-DHAVE_CONFIG_H
-I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include
-std=gnu99
-I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310
-DASM -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9
-O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration
-Wstrict-prototypes -Wnested-externs -MT libbsp_a-bsp-start-memcpy.o -MD
-MP -MF .deps/libbsp_a-bsp-start-memcpy.Tpo -c -o
libbsp_a-bsp-start-memcpy.o `test -f '../shared/startup/bsp-start-memcpy.S'
|| echo
'../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../shared/startup/bsp-start-memcpy.S
mv -f .deps/libbsp_a-bsp-start-memcpy.Tpo .deps/libbsp_a-bsp-start-memcpy.Po
-DHAVE_CONFIG_H
-std=gnu99
-march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g
-Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT
libbsp_a-arm-cp15-set-exception-handler.o -MD -MP -MF
.deps/libbsp_a-arm-cp15-set-exception-handler.Tpo -c -o
libbsp_a-arm-cp15-set-exception-handler.o `test -f
'../shared/arm-cp15-set-exception-handler.c' || echo
'../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../shared/arm-cp15-set-exception-handler.c
arm-rtems4.11-gcc.exe: error:
../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-cp15-set-exception-handler.c:
No such file or directory
arm-rtems4.11-gcc.exe: fatal error: no input files
compilation terminated.
make[6]: *** [Makefile:1080: libbsp_a-arm-cp15-set-exception-handler.o]
Error 1
make[6]: Leaving directory
'/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libbsp/arm/altera-cyclone-v'
make[5]: *** [Makefile:388: all-recursive] Error 1
make[5]: Leaving directory
'/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libbsp/arm'
make[4]: *** [Makefile:395: all-recursive] Error 1
make[4]: Leaving directory
'/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libbsp'
make[3]: *** [Makefile:310: all-recursive] Error 1
make[3]: Leaving directory
'/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib'
make[2]: *** [Makefile:424: all-recursive] Error 1
make[2]: Leaving directory
'/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit'
make[1]: *** [Makefile:286: all-recursive] Error 1
make[1]: Leaving directory
'/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c'
make: *** [Makefile:410: all-recursive] Error 1
shell cmd failed: sh -ex /D/opt/rtems/4.11.2/rtems/build/ark41/doit
error: building ark41
See error report: rsb-report-arm-rtems4.11-kernel-4.11.2-1.txt
Build Set: Time 5:21:41.135878
URL: <http://lists.rtems.org/pipermail/users/attachments/20171113/4710ed05/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
Build: error: building ark41
Command Line: ../source-builder/sb-set-builder --jobs=none --prefix=D:/opt/rtems/4.11 4.11/rtems-arm
Python: 2.7.14 (default, Sep 18 2017, 09:17:44) [GCC 7.2.0 64 bit (AMD64)]
Windows
Tail of the build log:
/usr/bin/install -c -m 644 libtelnetd.a ../../cpukit/../../../altcycv_devkit/lib/libtelnetd.a
make[5]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/cpukit/telnetd'
Making all in pppd
make[5]: Entering directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/cpukit/pppd'
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-auth.o -MD -MP -MF .deps/libpppd_a-auth.Tpo -c -o libpppd_a-auth.o `test -f 'auth.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`auth.c
mv -f .deps/libpppd_a-auth.Tpo .deps/libpppd_a-auth.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-ccp.o -MD -MP -MF .deps/libpppd_a-ccp.Tpo -c -o libpppd_a-ccp.o `test -f 'ccp.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`ccp.c
mv -f .deps/libpppd_a-ccp.Tpo .deps/libpppd_a-ccp.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-chap.o -MD -MP -MF .deps/libpppd_a-chap.Tpo -c -o libpppd_a-chap.o `test -f 'chap.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`chap.c
mv -f .deps/libpppd_a-chap.Tpo .deps/libpppd_a-chap.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-chap_ms.o -MD -MP -MF .deps/libpppd_a-chap_ms.Tpo -c -o libpppd_a-chap_ms.o `test -f 'chap_ms.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`chap_ms.c
mv -f .deps/libpppd_a-chap_ms.Tpo .deps/libpppd_a-chap_ms.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-chat.o -MD -MP -MF .deps/libpppd_a-chat.Tpo -c -o libpppd_a-chat.o `test -f 'chat.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`chat.c
../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/chat.c:221:7: warning: no previous prototype for 'getnextcommand' [-Wmissing-prototypes]
char *getnextcommand(char *string,char *buff)
mv -f .deps/libpppd_a-chat.Tpo .deps/libpppd_a-chat.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-demand.o -MD -MP -MF .deps/libpppd_a-demand.Tpo -c -o libpppd_a-demand.o `test -f 'demand.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`demand.c
mv -f .deps/libpppd_a-demand.Tpo .deps/libpppd_a-demand.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-fsm.o -MD -MP -MF .deps/libpppd_a-fsm.Tpo -c -o libpppd_a-fsm.o `test -f 'fsm.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`fsm.c
mv -f .deps/libpppd_a-fsm.Tpo .deps/libpppd_a-fsm.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-ipcp.o -MD -MP -MF .deps/libpppd_a-ipcp.Tpo -c -o libpppd_a-ipcp.o `test -f 'ipcp.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`ipcp.c
mv -f .deps/libpppd_a-ipcp.Tpo .deps/libpppd_a-ipcp.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-lcp.o -MD -MP -MF .deps/libpppd_a-lcp.Tpo -c -o libpppd_a-lcp.o `test -f 'lcp.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`lcp.c
mv -f .deps/libpppd_a-lcp.Tpo .deps/libpppd_a-lcp.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-magic.o -MD -MP -MF .deps/libpppd_a-magic.Tpo -c -o libpppd_a-magic.o `test -f 'magic.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`magic.c
mv -f .deps/libpppd_a-magic.Tpo .deps/libpppd_a-magic.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-options.o -MD -MP -MF .deps/libpppd_a-options.Tpo -c -o libpppd_a-options.o `test -f 'options.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`options.c
mv -f .deps/libpppd_a-options.Tpo .deps/libpppd_a-options.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-upap.o -MD -MP -MF .deps/libpppd_a-upap.Tpo -c -o libpppd_a-upap.o `test -f 'upap.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`upap.c
mv -f .deps/libpppd_a-upap.Tpo .deps/libpppd_a-upap.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-utils.o -MD -MP -MF .deps/libpppd_a-utils.Tpo -c -o libpppd_a-utils.o `test -f 'utils.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`utils.c
mv -f .deps/libpppd_a-utils.Tpo .deps/libpppd_a-utils.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-sys-rtems.o -MD -MP -MF .deps/libpppd_a-sys-rtems.Tpo -c -o libpppd_a-sys-rtems.o `test -f 'sys-rtems.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`sys-rtems.c
mv -f .deps/libpppd_a-sys-rtems.Tpo .deps/libpppd_a-sys-rtems.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-rtemsmain.o -MD -MP -MF .deps/libpppd_a-rtemsmain.Tpo -c -o libpppd_a-rtemsmain.o `test -f 'rtemsmain.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`rtemsmain.c
../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/rtemsmain.c:560:1: warning: no previous prototype for 'protocol_name' [-Wmissing-prototypes]
protocol_name(
mv -f .deps/libpppd_a-rtemsmain.Tpo .deps/libpppd_a-rtemsmain.Po
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -D__BSD_VISIBLE -I../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/../libmd -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libpppd_a-rtemspppd.o -MD -MP -MF .deps/libpppd_a-rtemspppd.Tpo -c -o libpppd_a-rtemspppd.o `test -f 'rtemspppd.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/pppd/'`rtemspppd.c
mv -f .deps/libpppd_a-rtemspppd.Tpo .deps/libpppd_a-rtemspppd.Po
rm -f libpppd.a
arm-rtems4.11-ar cru libpppd.a libpppd_a-auth.o libpppd_a-ccp.o libpppd_a-chap.o libpppd_a-chap_ms.o libpppd_a-chat.o libpppd_a-demand.o libpppd_a-fsm.o libpppd_a-ipcp.o libpppd_a-lcp.o libpppd_a-magic.o libpppd_a-options.o libpppd_a-upap.o libpppd_a-utils.o libpppd_a-sys-rtems.o libpppd_a-rtemsmain.o libpppd_a-rtemspppd.o
D:\opt\rtems\4.11.2\rtems\build\tmp\sb-IAI\4.11\rtems-arm\D\opt\rtems\4.11\bin\arm-rtems4.11-ar.exe: `u' modifier ignored since `D' is the default (see `U')
arm-rtems4.11-ranlib libpppd.a
/usr/bin/install -c -m 644 libpppd.a ../../cpukit/../../../altcycv_devkit/lib/libpppd.a
make[5]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/cpukit/pppd'
Making all in mghttpd
make[5]: Entering directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/cpukit/mghttpd'
arm-rtems4.11-gcc --pipe -DHAVE_CONFIG_H -I.. -I../../cpukit/../../../altcycv_devkit/lib/include -DNO_SSL -DNO_POPEN -DNO_CGI -DUSE_WEBSOCKET -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libmghttpd_a-mongoose.o -MD -MP -MF .deps/libmghttpd_a-mongoose.Tpo -c -o libmghttpd_a-mongoose.o `test -f 'mongoose.c' || echo '../../../../../../rtems-4.11.2/c/src/../../cpukit/mghttpd/'`mongoose.c
mv -f .deps/libmghttpd_a-mongoose.Tpo .deps/libmghttpd_a-mongoose.Po
rm -f libmghttpd.a
arm-rtems4.11-ar cru libmghttpd.a libmghttpd_a-mongoose.o
arm-rtems4.11-ranlib libmghttpd.a
/usr/bin/install -c -m 644 libmghttpd.a ../../cpukit/../../../altcycv_devkit/lib/libmghttpd.a
make[5]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/cpukit/mghttpd'
make[4]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/cpukit'
make[3]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/cpukit'
Making all in make
make[3]: Entering directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/make'
sed \
-e "s|[@]prefix[@]|/D/opt/rtems/4.11|" \
-e "s|[@]exec_prefix[@]|/D/opt/rtems/4.11/arm-rtems4.11|" \
-e "s|[@]pkgdatadir[@]|/D/opt/rtems/4.11/share/rtems4.11|" \
-e "s|[@]RTEMS_BSP[@]|altcycv_devkit|" \
-e "s|[@]CC[@]|arm-rtems4.11-gcc --pipe|" \
-e "s|[@]CXX[@]|arm-rtems4.11-g++|" \
-e "s|[@]AS[@]|arm-rtems4.11-as|" \
-e "s|[@]AR[@]|arm-rtems4.11-ar|" \
-e "s|[@]NM[@]|arm-rtems4.11-nm|" \
-e "s|[@]LD[@]|arm-rtems4.11-ld|" \
-e "s|[@]SIZE[@]|arm-rtems4.11-size|" \
-e "s|[@]OBJCOPY[@]|arm-rtems4.11-objcopy|" \
-e "s|[@]RTEMS_HAS_POSIX_API[@]|yes|" \
-e "s|[@]RTEMS_HAS_CPLUSPLUS[@]|yes|" \
< ../../../../../rtems-4.11.2/c/src/make/Makefile.inc.in > Makefile.inc
sed \
-e "s|[@]HAS_MP[@]||" \
-e "s|[@]HAS_POSIX_API[@]|yes|" \
-e "s|[@]HAS_CPLUSPLUS[@]|yes|" \
-e "s|[@]HAS_NETWORKING[@]|yes|" \
< ../../../../../rtems-4.11.2/c/src/make/bsp.cfg.in > bsp.cfg
sed \
-e "s|[@]RTEMS_API[@]|4.11|" \
-e "s|[@]CPPFLAGS[@]||" \
-e "s|[@]CFLAGS[@]|-march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs|" \
-e "s|[@]LIBS[@]||" \
-e "s|[@]STRIP[@]|arm-rtems4.11-strip|" \
-e "s|[@]RANLIB[@]|arm-rtems4.11-ranlib|" \
-e "s|[@]RTEMS_CPU[@]|arm|" \
-e "s|[@]RTEMS_HAS_MULTIPROCESSING[@]||" \
-e "s|[@]RTEMS_HAS_NETWORKING[@]|yes|" \
< ../../../../../rtems-4.11.2/c/src/make/target.cfg.in > target.cfg
sed \
-e "s|[@]CP[@]|/usr/bin/cp|" \
-e "s|[@]MV[@]|/usr/bin/mv|" \
-e "s|[@]LN[@]|/usr/bin/ln|" \
-e "s|[@]SHELL[@]|/bin/sh|" \
-e "s|[@]KSH[@]|/usr/bin/bash|" \
< ../../../../../rtems-4.11.2/c/src/make/host.cfg.in > host.cfg
make[3]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/make'
Making all in lib
make[3]: Entering directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib'
Making all in libcpu
make[4]: Entering directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libcpu'
Making all in arm
make[5]: Entering directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libcpu/arm'
make[5]: Nothing to be done for 'all'.
make[5]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libcpu/arm'
make[5]: Entering directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libcpu'
make[5]: Nothing to be done for 'all-am'.
make[5]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libcpu'
make[4]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libcpu'
Making all in libbsp
make[4]: Entering directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libbsp'
Making all in arm
make[5]: Entering directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libbsp/arm'
Making all in altera-cyclone-v
make[6]: Entering directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libbsp/arm/altera-cyclone-v'
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../.././altcycv_devkit/lib/include -DASM -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT start.o -MD -MP -MF .deps/start.Tpo -c -o start.o `test -f '../shared/start/start.S' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../shared/start/start.S
mv -f .deps/start.Tpo .deps/start.Po
rm -f libbspstart.a
arm-rtems4.11-ar cru libbspstart.a start.o
arm-rtems4.11-ranlib libbspstart.a
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-alt_16550_uart.o -MD -MP -MF .deps/libbsp_a-alt_16550_uart.Tpo -c -o libbsp_a-alt_16550_uart.o `test -f 'hwlib/src/hwmgr/alt_16550_uart.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`hwlib/src/hwmgr/alt_16550_uart.c
mv -f .deps/libbsp_a-alt_16550_uart.Tpo .deps/libbsp_a-alt_16550_uart.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-alt_address_space.o -MD -MP -MF .deps/libbsp_a-alt_address_space.Tpo -c -o libbsp_a-alt_address_space.o `test -f 'hwlib/src/hwmgr/alt_address_space.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`hwlib/src/hwmgr/alt_address_space.c
mv -f .deps/libbsp_a-alt_address_space.Tpo .deps/libbsp_a-alt_address_space.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-alt_clock_manager.o -MD -MP -MF .deps/libbsp_a-alt_clock_manager.Tpo -c -o libbsp_a-alt_clock_manager.o `test -f 'hwlib/src/hwmgr/alt_clock_manager.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`hwlib/src/hwmgr/alt_clock_manager.c
mv -f .deps/libbsp_a-alt_clock_manager.Tpo .deps/libbsp_a-alt_clock_manager.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-alt_dma.o -MD -MP -MF .deps/libbsp_a-alt_dma.Tpo -c -o libbsp_a-alt_dma.o `test -f 'hwlib/src/hwmgr/alt_dma.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`hwlib/src/hwmgr/alt_dma.c
mv -f .deps/libbsp_a-alt_dma.Tpo .deps/libbsp_a-alt_dma.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-alt_dma_program.o -MD -MP -MF .deps/libbsp_a-alt_dma_program.Tpo -c -o libbsp_a-alt_dma_program.o `test -f 'hwlib/src/hwmgr/alt_dma_program.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`hwlib/src/hwmgr/alt_dma_program.c
mv -f .deps/libbsp_a-alt_dma_program.Tpo .deps/libbsp_a-alt_dma_program.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-alt_generalpurpose_io.o -MD -MP -MF .deps/libbsp_a-alt_generalpurpose_io.Tpo -c -o libbsp_a-alt_generalpurpose_io.o `test -f 'hwlib/src/hwmgr/alt_generalpurpose_io.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`hwlib/src/hwmgr/alt_generalpurpose_io.c
mv -f .deps/libbsp_a-alt_generalpurpose_io.Tpo .deps/libbsp_a-alt_generalpurpose_io.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-alt_i2c.o -MD -MP -MF .deps/libbsp_a-alt_i2c.Tpo -c -o libbsp_a-alt_i2c.o `test -f 'hwlib/src/hwmgr/alt_i2c.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`hwlib/src/hwmgr/alt_i2c.c
mv -f .deps/libbsp_a-alt_i2c.Tpo .deps/libbsp_a-alt_i2c.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-alt_qspi.o -MD -MP -MF .deps/libbsp_a-alt_qspi.Tpo -c -o libbsp_a-alt_qspi.o `test -f 'hwlib/src/hwmgr/alt_qspi.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`hwlib/src/hwmgr/alt_qspi.c
mv -f .deps/libbsp_a-alt_qspi.Tpo .deps/libbsp_a-alt_qspi.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-alt_reset_manager.o -MD -MP -MF .deps/libbsp_a-alt_reset_manager.Tpo -c -o libbsp_a-alt_reset_manager.o `test -f 'hwlib/src/hwmgr/alt_reset_manager.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`hwlib/src/hwmgr/alt_reset_manager.c
mv -f .deps/libbsp_a-alt_reset_manager.Tpo .deps/libbsp_a-alt_reset_manager.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-bootcard.o -MD -MP -MF .deps/libbsp_a-bootcard.Tpo -c -o libbsp_a-bootcard.o `test -f '../../shared/bootcard.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/bootcard.c
mv -f .deps/libbsp_a-bootcard.Tpo .deps/libbsp_a-bootcard.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-bspclean.o -MD -MP -MF .deps/libbsp_a-bspclean.Tpo -c -o libbsp_a-bspclean.o `test -f '../../shared/bspclean.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/bspclean.c
mv -f .deps/libbsp_a-bspclean.Tpo .deps/libbsp_a-bspclean.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-bspgetworkarea.o -MD -MP -MF .deps/libbsp_a-bspgetworkarea.Tpo -c -o libbsp_a-bspgetworkarea.o `test -f '../../shared/bspgetworkarea.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/bspgetworkarea.c
mv -f .deps/libbsp_a-bspgetworkarea.Tpo .deps/libbsp_a-bspgetworkarea.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-bsplibc.o -MD -MP -MF .deps/libbsp_a-bsplibc.Tpo -c -o libbsp_a-bsplibc.o `test -f '../../shared/bsplibc.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/bsplibc.c
mv -f .deps/libbsp_a-bsplibc.Tpo .deps/libbsp_a-bsplibc.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-bsppost.o -MD -MP -MF .deps/libbsp_a-bsppost.Tpo -c -o libbsp_a-bsppost.o `test -f '../../shared/bsppost.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/bsppost.c
mv -f .deps/libbsp_a-bsppost.Tpo .deps/libbsp_a-bsppost.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-bsppredriverhook.o -MD -MP -MF .deps/libbsp_a-bsppredriverhook.Tpo -c -o libbsp_a-bsppredriverhook.o `test -f '../../shared/bsppredriverhook.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/bsppredriverhook.c
mv -f .deps/libbsp_a-bsppredriverhook.Tpo .deps/libbsp_a-bsppredriverhook.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-bsppretaskinghook.o -MD -MP -MF .deps/libbsp_a-bsppretaskinghook.Tpo -c -o libbsp_a-bsppretaskinghook.o `test -f '../../shared/bsppretaskinghook.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/bsppretaskinghook.c
mv -f .deps/libbsp_a-bsppretaskinghook.Tpo .deps/libbsp_a-bsppretaskinghook.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-cpucounterdiff.o -MD -MP -MF .deps/libbsp_a-cpucounterdiff.Tpo -c -o libbsp_a-cpucounterdiff.o `test -f '../../shared/cpucounterdiff.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/cpucounterdiff.c
mv -f .deps/libbsp_a-cpucounterdiff.Tpo .deps/libbsp_a-cpucounterdiff.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-gnatinstallhandler.o -MD -MP -MF .deps/libbsp_a-gnatinstallhandler.Tpo -c -o libbsp_a-gnatinstallhandler.o `test -f '../../shared/gnatinstallhandler.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/gnatinstallhandler.c
mv -f .deps/libbsp_a-gnatinstallhandler.Tpo .deps/libbsp_a-gnatinstallhandler.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-sbrk.o -MD -MP -MF .deps/libbsp_a-sbrk.Tpo -c -o libbsp_a-sbrk.o `test -f '../../shared/sbrk.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/sbrk.c
mv -f .deps/libbsp_a-sbrk.Tpo .deps/libbsp_a-sbrk.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-timerstub.o -MD -MP -MF .deps/libbsp_a-timerstub.Tpo -c -o libbsp_a-timerstub.o `test -f '../../shared/timerstub.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/timerstub.c
mv -f .deps/libbsp_a-timerstub.Tpo .deps/libbsp_a-timerstub.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-stackalloc.o -MD -MP -MF .deps/libbsp_a-stackalloc.Tpo -c -o libbsp_a-stackalloc.o `test -f '../../shared/src/stackalloc.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../../shared/src/stackalloc.c
mv -f .deps/libbsp_a-stackalloc.Tpo .deps/libbsp_a-stackalloc.Po
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -DASM -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -MT libbsp_a-bsp-start-memcpy.o -MD -MP -MF .deps/libbsp_a-bsp-start-memcpy.Tpo -c -o libbsp_a-bsp-start-memcpy.o `test -f '../shared/startup/bsp-start-memcpy.S' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../shared/startup/bsp-start-memcpy.S
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/ -B../../../../../.././altcycv_devkit/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/hwlib/include -std=gnu99 -I../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-l2c-310 -march=armv7-a -mthumb -mfpu=neon -mfloat-abi=hard -mtune=cortex-a9 -O2 -g -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs -Wno-missing-prototypes -MT libbsp_a-arm-cp15-set-exception-handler.o -MD -MP -MF .deps/libbsp_a-arm-cp15-set-exception-handler.Tpo -c -o libbsp_a-arm-cp15-set-exception-handler.o `test -f '../shared/arm-cp15-set-exception-handler.c' || echo '../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/'`../shared/arm-cp15-set-exception-handler.c
arm-rtems4.11-gcc.exe: error: ../../../../../../../../rtems-4.11.2/c/src/lib/libbsp/arm/altera-cyclone-v/../shared/arm-cp15-set-exception-handler.c: No such file or directory
make[6]: *** [Makefile:1080: libbsp_a-arm-cp15-set-exception-handler.o] Error 1
make[6]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libbsp/arm/altera-cyclone-v'
make[5]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libbsp/arm'
make[4]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib/libbsp'
make[3]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit/lib'
make[2]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c/altcycv_devkit'
make[1]: Leaving directory '/D/opt/rtems/4.11.2/rtems/build/ark41/arm-rtems4.11-kernel-4.11.2-1-4.11.2/build/arm-rtems4.11/c'
