Stack_check_Dump_threads_usage printing out the wrong values
Mr. Andrei Chichak
groups at chichak.ca
Wed Nov 15 22:50:53 UTC 2017
I’m working with 4.12 for ARM (cortex M7)
I’m tracing down an issue and figured it smelled like a stack problem, so I got my command line interpreter to call rtems_stack_checker_report_usage().
The addresses that it is printing out are just wrong.
STACK USAGE BY THREAD
ID NAME LOW HIGH CURRENT AVAIL USED
0x09010001 IDLE 0x536902024 0x536906119 0x536906024 4080 164
0x0A010001 UI1 0x536906128 0x536910223 0x536910112 4080 404
0x0A010002 CfgT 0x536910232 0x536914327 0x536914120 4080 288
0x0A010003 LOGT 0x536914728 0x536918823 0x536918248 4080 648
0x0A010004 MonT 0x536918832 0x536922927 0x536922592 4080 404
0x0A010005 ADCT 0x536922936 0x536927031 0x536926712 4080 388
0x0A010006 CSLT 0x536927040 0x536931135 0x536930512 4080 1236
So I started chasing the source code and I find that on line 408 of check.c in function Stack_check_Dump_threads_usage, in the line:
rtems_printf(
printer,
"0x%08" PRIx32 " %-21s 0x%08" PRIuPTR " 0x%08" PRIuPTR " 0x%08" PRIuPTR " %6" PRId32 " ",
id,
name,
(uintptr_t) stack->area,
(uintptr_t) stack->area + (uintptr_t) stack->size - 1,
(uintptr_t) current,
size
Stack->area has the value 0x20009998 and the value of stack->size is 4096 ( for process CfgT). Current has the value 0x2000a8c8.
AH, I get it, the values are being prepended with 0x and then printing out in decimal instead of hex.
Perhaps in the format, the PRIuPTRs should be PRIx32s instead???
Andrei
URL: <http://lists.rtems.org/pipermail/users/attachments/20171115/a6b3ef14/attachment.html>
