Stack_check_Dump_threads_usage printing out the wrong values
Wed Nov 15 23:10:32 UTC 2017
On 16/11/2017 09:50, Mr. Andrei Chichak wrote:
> I’m working with 4.12 for ARM   (cortex M7)
> I’m tracing down an issue and figured it smelled like a stack problem, so I got
> my command line interpreter to call rtems_stack_checker_report_usage().
> The addresses that it is printing out are just wrong.
>                              STACK USAGE BY THREAD
> ID         NAME                  LOW        HIGH       CURRENT    AVAIL  USED
> 0x09010001 IDLE                  0x536902024 0x536906119 0x536906024   4080    164
> 0x0A010001 UI1                   0x536906128 0x536910223 0x536910112   4080    404
> 0x0A010002 CfgT                  0x536910232 0x536914327 0x536914120   4080    288
> 0x0A010003 LOGT                  0x536914728 0x536918823 0x536918248   4080    648
> 0x0A010004 MonT                  0x536918832 0x536922927 0x536922592   4080    404
> 0x0A010005 ADCT                  0x536922936 0x536927031 0x536926712   4080    388
> 0x0A010006 CSLT                  0x536927040 0x536931135 0x536930512   4080   1236
> So I started chasing the source code and I find that on line 408 of check.c in
> function Stack_check_Dump_threads_usage, in the line:
>   rtems_printf(
>     printer,
>     "0x%08" PRIx32 " %-21s 0x%08" PRIuPTR " 0x%08" PRIuPTR " 0x%08" PRIuPTR "
> %6" PRId32 " ",
>     id,
>     name,
>     (uintptr_t) stack->area,
>     (uintptr_t) stack->area + (uintptr_t) stack->size - 1,
>     (uintptr_t) current,
>     size
> Stack->area has the value 0x20009998 and the value of stack->size is 4096  ( for
> process CfgT). Current has the value 0x2000a8c8.
> AH, I get it, the values are being prepended with 0x and then printing out in
> decimal instead of hex.
Nice fine.
> Perhaps in the format, the PRIuPTRs should be PRIx32s instead???
Or PRIxPTR?
