Building RSB (RTEMS Source Builder) on Windows 10
Jacob Saina jsaina at terpmail.umd.edu
Tue Nov 14 20:44:53 UTC 2017
> >> 2) I've noticed that the "rsb-report-arm-rtems4.11-kernel...." file
> (attached)
> >> says "RSB: not a valid repo." What does this mean?
> > I suggest you try a build with `--without-rtems` on the command line. ...
> I've kicked off a build --without-rtems. But is this related to the "RSB:
> not a valid repo" message?
I'm home sick so I can't attach logs, but I've been informed that the
--without-rtems build has failed after 45 minutes:
error: building arg4n2xwml
URL: <http://lists.rtems.org/pipermail/users/attachments/20171114/68386e11/attachment-0002.html>
