Issue with Uart 0 in xilinx_zynq_zedboard BSP
Sergio Paracuellos sparacuellos at orbitalcs.com
Wed Oct 11 06:09:56 UTC 2017
Hi all,
I am using a zynq based board where uart zero is instantiated instead of
one. I have just set
configure.ac BSP_CONSOLE_MINOR variable to zero and compile rtems normally
(I am using rtems 4.11). I am able to run the samples but uart just give me
unintelligible symbols. I have never expected that behaviour with the
default uart 1 using zynq based boards. The only difference seems to be the
mapped memory region for the uart so I was wondering if I am just skipping
something. The minicom terminal program is configured correctly. I am able
to use the board with linux without any uart issues.
Is there any known issue with uart 0 in zynq based boards? Is neccassy to
change more stuff that console minor configure one?
Thanks in advance.
Cheers,
    Sergio Paracuellos
URL: <http://lists.rtems.org/pipermail/users/attachments/20171011/c985383e/attachment.html>
