Issue with Uart 0 in xilinx_zynq_zedboard BSP
Sergio Paracuellos sparacuellos at orbitalcs.com
Wed Oct 11 07:44:07 UTC 2017
Hi all,
I answer to myself. I had a problem with the uart clock. I was told that it
was at 50 MHz but it was at 100 instead.
Now uart zero is working properly.
Thanks!
2017-10-11 8:09 GMT+02:00 Sergio Paracuellos <sparacuellos at orbitalcs.com>:
> Hi all,
> I am using a zynq based board where uart zero is instantiated instead of
> one. I have just set
> configure.ac BSP_CONSOLE_MINOR variable to zero and compile rtems
> normally (I am using rtems 4.11). I am able to run the samples but uart
> just give me unintelligible symbols. I have never expected that behaviour
> with the default uart 1 using zynq based boards. The only difference seems
> to be the mapped memory region for the uart so I was wondering if I am just
> skipping something. The minicom terminal program is configured correctly. I
> am able to use the board with linux without any uart issues.
> Is there any known issue with uart 0 in zynq based boards? Is neccassy to
> change more stuff that console minor configure one?
> Thanks in advance.
> Cheers,
>     Sergio Paracuellos
URL: <http://lists.rtems.org/pipermail/users/attachments/20171011/14ad2111/attachment-0002.html>
