MIssing pci/cfg.h during PCI configuration
Thu Oct 19 05:04:46 UTC 2017
Hello Jan,
On 18/10/17 17:24, Jan.Sommer at dlr.de wrote:
> Hello,
> I try to create a simple rtems4.12 setup using the pc486 bsp with the PCI-library enabled.
> Following the user guide I added
> #define RTEMS_PCI_CONFIG_LIB
> #define CONFIGURE_INIT
> #define CONFIGURE_PCI_LIB            PCI_LIB_AUTO
> to my configuration.
> If I try to compile the project I get the error: pc486/lib/include/rtems/confdefs.h:3254:16: fatal error: pci/cfg.h: No such file or directory
the libpci is currently only available on SPARC. In general, I would use
the libbsd for PCI support.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
