Filesystem in RTEMS
xuelin.tian at qkmtech.com
Mon Oct 23 01:53:28 UTC 2017
Yes, Everything is going well, if I erase the flash before use.
But, I need to store some files into flash, and reuse them when I restart my system. I can not erase the flash every time.
Best wishes,
Date: 2017-10-23 07:01
To: xuelin.tian at qkmtech.com; Sebastian Huber
CC: users at rtems.org
Subject: Re: Filesystem in RTEMS
On 22/10/2017 21:00, xuelin.tian at qkmtech.com wrote:
> Everything worked well, after erasing the whole flash. But errors came up
> without erasing it.
You need to erase the flash before use. JFFS2 cannot tell the flash was unused
and available for use so it has to assume it has become corrupted and reports this.
URL: <http://lists.rtems.org/pipermail/users/attachments/20171023/0cce1d90/attachment-0001.html>
