Filesystem in RTEMS
    Chris Johns
    chrisj at rtems.org
    Mon Oct 23 04:19:10 UTC 2017
On 23/10/2017 12:53, xuelin.tian at qkmtech.com wrote:
> Yes, Everything is going well, if I erase the flash before use.
> But, I need to store some files into flash, and reuse them when I restart my
> system. I can not erase the flash every time.
Oh I see what you are saying.
I am using the JFFS2 on a Zynq with a 64M byte SPI flash and seeing no issues. I
suggest you check your flash driver and make sure you are writing to the flash
correctly.
