Installing cexp-2.2.3 for RTEMS 4.12
Till Straumann
strauman at slac.stanford.edu
Mon Oct 23 01:42:01 UTC 2017
I have updated cexp so it should build for rtems-4.12.
git://github.com/till-s/cexpsh
Also supports ARM now.
- T.
On 10/05/2017 04:06 PM, Akiv wrote:
> Hi All,
> I have built RTEMS 4.12 for the pc686 BSP. I am now trying to install
> cexp 2.2.3. My goal is to run pc-rtems according to this guide:
> https://github.com/nasa/cFE/tree/master/psp/fsw/pc-rtems.
> After configuring, when I run the make I get the following error.
> bash-4.1$ ../cexp-CEXP_Release_2_2_3/configure
> --with-rtems-top=/home/rtems/pc_rtems/development/rtems/4.12
> --host=i386-rtems4.12 --enable-std-rtems-installdirs
> bash-4.1$ make -j 8
> make all-recursive
> make[1]: Entering directory
> `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp'
> Making all in pc686
> make[2]: Entering directory
> `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686'
> make all-recursive
> make[3]: Entering directory
> Making all in regexp
> make[4]: Entering directory
> `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686/regexp'
> make[4]: Nothing to be done for `all'.
> make[4]: Leaving directory
> Making all in libtecla
> `/home/rtems/pc_rtems/development/rtems/kernel/b-cexp/pc686/libtecla'
> i386-rtems4.12-gcc
> -B/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/pc686/lib/
> -specs bsp_specs -qrtems -B
> /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/lib
> -mtune=pentiumpro -march=pentium
> -I/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/pc686/lib/include
> -I/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include
> -DPACKAGE_NAME=\"\" -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\"
> -DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\"
> -DPACKAGE=\"libtecla\" -DVERSION=\"1.0\" -DSTDC_HEADERS=1
> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
> -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
> -DHAVE_SYS_SELECT_H=1 -DHAVE_SELECT=1 -I.
> -I../..//../cexp-CEXP_Release_2_2_3/libtecla
> -I../..//../cexp-CEXP_Release_2_2_3/libtecla/.. -DPACKAGE_NAME=\"\"
> -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\" -DPACKAGE_STRING=\"\"
> -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -DPACKAGE=\"libtecla\"
> -DVERSION=\"1.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1
> -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1
> -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1
> -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_SELECT_H=1
> -DHAVE_SELECT=1 -MT libtecla_a-getline.o -MD -MP -MF
> .deps/libtecla_a-getline.Tpo -c -o libtecla_a-getline.o `test -f
> 'getline.c' || echo
> '../..//../cexp-CEXP_Release_2_2_3/libtecla/'`getline.c
> i386-rtems4.12-gcc
> -D_POSIX_C_SOURCE=199506L -DPREFER_REENTRANT -MT
> libtecla_r_a-getline.o -MD -MP -MF .deps/libtecla_r_a-getline.Tpo -c
> -o libtecla_r_a-getline.o `test -f 'getline.c' || echo
> In file included from
> ../..//../cexp-CEXP_Release_2_2_3/libtecla/getline.c:154:0:
> ../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:60:2:
> error: #error "This file is deprecated; remove this line if you
> absolutely have to use it"
> #error "This file is deprecated; remove this line if you absolutely
> have to use it"
> ../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:62:8:
> error: redefinition of 'struct winsize'
> struct winsize {
> /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ioctl.h:49:0,
> from
> ../..//../cexp-CEXP_Release_2_2_3/libtecla/getline.c:59:
> /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ttycom.h:52:8:
> note: originally defined here
> struct winsize {
> ../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:74:0:
> warning: "IOCPARM_MASK" redefined
> #define IOCPARM_MASK 0x1fff /* parameter length, at most 13 bits */
> /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ioctl.h:45:0,
> from
> /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ioccom.h:47:0:
> note: this is the location of the previous definition
> #define IOCPARM_MASK ((1 << IOCPARM_SHIFT) - 1) /* parameter length
> mask */
> ../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:76:0:
> warning: "_IOC" redefined
> #define _IOC(inout,group,num,len) (inout | ((len & IOCPARM_MASK) <<
> 16) | ((group) << 8) | (num))
> from
> /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ioccom.h:59:0:
> #define _IOC(inout,group,num,len) \
> have to use it"
> struct winsize {
> from
> struct winsize {
> from
> mask */
> from
> make[4]: *** [libtecla_r_a-getline.o] Error 1
> make[4]: *** Waiting for unfinished jobs....
> make[4]: *** [libtecla_a-getline.o] Error 1
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory
> make[2]: *** [all] Error 2
> make[2]: Leaving directory
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory
> make: *** [all] Error 2
> Would someone be able to provide some insight?
> Best Regards,
> Akiv Jhirad
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20171022/d84d6706/attachment-0002.html>
